Why we need to convert OST format to PST format?
Sometimes earlier my ost file damaged and now I want to recover it because many important files are attached in the same. Can anyone please suggest me the best software.
    AngeliqueAngelique
    edited January 2019
    There is a many reason for using a OST to PST Converter which lets users switch to outlook or damaged ost file etc., OST files directly from the outlook through different file formats to save in the mailbox data. It is because Outlook use a specific format such as OST file format and PST file format is used with outlook. While the OST to PST Converter generally used because of the damaged or corrupted data which is not returnable by common means. The manual method is also cumbersome and occupies a lot of time. Use of an Inspire OST to PST Converter helps in converting OST to PST files.
    Download demo Version - https://download.cnet.com/Inspire-Data-Care-OST-to-PST-Converter-Software/3000-2369_4-77970315.html
    You may require migrating from OST file to PST in any of the following cases:
    • Your mailbox on the Exchange Server is deleted accidentally and you need to access your emails.
    • You are facing issues while synchronizing MS Outlook with Exchange Server.
    • You need to carry your business emails to a different workplace or organization
    Now, you can go with the OST to PST Converter software, if you required to recover and export OST to PST and Office 365.
    Have a look here: https://www.nucleustechnologies.com/blog/free-methods-convert-ost-to-pst-file/
    This is an article about OST to PST conversion methods. Here , you can find out information about free as well as paid methods to convert OST to PST files.
    The OST to PST Migration Tool professionally moves OST files Outlook PST format. The OST to PST Convert Tool is an effective utility, whereby users can readily migrate OST mailbox to PST. This software keeps the original data format after the converter. Get more information here: https://www.sametools.com/convert/ost/
    You can also utilise OST to PST Exporter Software to migrate OST to PST. It provides you the ability to change OST file of any size into PST. Download Demo version of OST to PST exchange for free. Feel the change yourself from other products of the same category. Click here: https://www.downloadfreeware.org/ost-pst-converter/
