Holographic Remoting over USB Connection
Anyone figure out how to get the Holographic Remoting player to work over the 127.0.0.1 USB connection.
There should be a way to do it if one knew the port that the remoting player uses since you could just go to regedit HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\IpOverUsbKit and add an entry in there to map the ports appropriately
I would also like to be able to do this. I already have the USB connected for quick and easy connection to my device from Visual Studio. This would give a more reliable connection than wifi and it would be nice not to need to type in the IP address.
Has anyone figured out if we can use USB connection with the Holographic Remoting app instead of Wi-Fi? I am not permitted to use Wi-Fi in my workplace for security reasons, so my only option is USB. Should be possible... but not sure how?? Any Help?
