How to Convert my OST file into PST format?
You can also utilize OST to PST Exporter Software to migrate OST to PST. It provides you the ability to change OST file of any size into PST. Download Demo version of OST to PST exchange for free. Feel the change yourself from other products of the same category. Click here: https://www.gaintools.com/ost/pst/
  • Another easy yet simple OST to PST converter which can help you save multiple OST files into PST file format is here. You can opt OST to PST conversion tool to migrate complete data from a OST file into Outlook PST file format keeping the folder structure and other associated data intact. Visit for more : https://www.datavare.com/software/ost-to-pst-converter-expert.html
  • A very easy and one of the best possible solution is OST to PST file converter. You can convert the files very quickly & effortlessly and it can repair corrupt OST files too without any hassle. For more information and downloading of software visit this link: http://www.osttopstfileconverter.com/
  • You can try OST to PST Converter which has capability to convert corrupted OST files as well as convert pst mailbox. There facility now save individual OST mailboxes data into PST file format. With ost to pst tool convert corrupted OST file in PST format.
    visit here more info: http://www.osttopstapp.com/
  • Hi, you can also try the manual method to convert OST to PST.
    1. Open MS Outlook.
    2. Click on File>>Open & Export>>Import and Export option.
    3. Navigate to Export to a file and then click on Next.
    4. Choose Outlook Data File (.pst) & click on Next.
    5. Select the folder for importing the items.
    6. Give the location for the folder to save the PST file and click on Finish.
  • I would suggest you the easiest way to convert OST files into PST by using Indya OST to PST Converter. It has very simple graphical users interface so that all the users can easily use this tool to perform the conversion. The tool has no limitations to export offline OST files to PST format. You can convert large number of OST files into PST format without any size limit.
  • Try OST to PST Conversion Software and recover corrupted OST data and convert into Outlook PST format with all Emails, Contacts, calendar , Notes, entries, and journals.This software supports Windows 10, 8, 7, Vista, XP and MS Office 2016,2013, 2010, 2007, 2003, 2002 (XP). Read more information about this software and free download click here http://osttopstconversion-software.blogspot.com
  • If you want to convert your OST file to PST file format then try Exchange OST Recovery Tool which has the ability to perform complete recovery of the corrupt OST file with the restoration of metadata for the items like emails, calendar, contacts, appointments, tasks, journals, notes, etc. at a single go.
  • "How to Convert my OST file into PST format?" People May Ask
    Converting your stored OST mails to Outlook personal folder isn't easy to do the stuff you must need an third party solution, so quickly do the email conversion task with OST to PST file tool, it's an hassle-free solution to convert, extract or restore OST mails from Offline / Exchange stored location to Outlook .PST folder, batch conversion is also allowed.
  • Are you thinking to convert your outlook ost mails to pst due to of any reason such as ost corruption or ost mails not access properly on outlook .
    So choose best sifo systems outlook ost to pst converter software tool which allows you perfect conversion of database from ost to pst file with all of database such as inbox,calendar ,notes,contacts,task,etc .
    This software support all version of ms outlook by which you can easily this software tool for all outlook ost files (2016,2013,2010,2007,2003,etc ).
    You can also convert ost to pst,ost to eml,ost to msg,ost to html,etc .
    Go for free download of software ,click here :- sifo systems ost to pst converter software
  • Thank you all to share your crucial views on Hololens.
    On the web, I also found a blog post which helps to know step by step Manual method to convert OST file into PST format. https://www.shoviv.com/how-to/convert-ost-to-pst-step-by-step-using-the-manual-method.php
    Hope this post will help you.
  • ATS OST to PST converter tool has the more wonderful feature which helps you to restore lost and permanently deleted items and organize them back in the same file. It gives you a facility that you can easily retrieve OST file from damage Outlook OST file without any data change or data loss. It facilitates its user to see the preview of recovered OST file before the conversion of OST file into PST file. Convert OST file to PST give the option to download a free trial version and check efficiency and working process of the software before purchases this tool.
    Read More info: https://ats-ost-to-pst-converter-toolkit.en.softonic.com/
  • To export OST to PST file, OST to PST conversion software is best choice. By using an OST to PST converter software, you can fix OST errors and convert them in PST formats within few clicks. For more, visit: https://www.nucleustechnologies.com/supportcenter/kb/ost-to-pst-converter-full-version
  • HalochugHalochug
    edited December 2018
    If you want to convert OST to PST, you can either use Import/Export method or opt for any third-party SysInfo OST to PST Converter tool. Below are the steps to convert OST to PST using Import/Export method:
    • Go to File > Open & Export > Import/Export
    • Click on Export to a File.
    • Select Outlook Data File and click Next.
    • Opt for a folder or file that you want to export.
    • Here, you need to browse the location in order to save the exported data.
    Hope it helps..!!
  • Convert your ost file data to pst file in outlook using genuine ost to pst recovery software tool .Yes i am telling you about sifo systems ost to pst converter software tool that allows you recovery and conversion of database from outlook ost file to pst file even by showing of data preview on software screenshot such as inbox,calendar ,contacts,task,etc .
    Software support all version of ms outlook which are ost 2016,ost 2013,ost 2010,ost 2007,ost 2003,etc .
    Go for free download of software ,click here :- sifo systems ost to pst software
  • Try to One of the best OST conversion tool see blog
    https://outlooksolutuion.wordpress.com/
  • You can use the outlook manual method “Outlook import-export” wizard to export OST file to PST. However, if the OST file is corrupt, then you won’t be able to use this method.
    However, the easiest way to convert your corrupt OST file to PST even if you are not connected to exchange is using a professional software solution. You can go with Stellar Converter for OST. One of the best tool to easily migrate your OST to PST. The tool provides you with all the relevant features and an easy to interface.
    You can visit the link for free download: https://gallery.technet.microsoft.com/OST-to-PST-Converter-to-33b84a13
  • This Software can easily Convert OST file into PST file format.
    CheckOut this Software free demo version from here:
    http://www.osttopstconverter.emltopstutility.com/
  • it is very simple to convert OST file into PST format
    follow following steps
    1- open - "https://www.duxdatarecovery.com/ost-to-pst-recovery.php"
    2- click on "try it free"
    3- install it
    now you can convert your OST file. t&c apply
    Read more - https://www.duxdatarecovery.com/ost-to-pst-recovery.php
  • Download free OST to PST converter and open and view OST file content without Exchange Server and Microsoft Outlook.
    If you need to convert OST file, you can also use this tool to convert OST file to PST and other popular file formats.
  • After reading your question, I can understand that you want to know how to convert your OST file in PST format. You can take help of any third party software like Microsoft OST to PST converter by KDETools. You just need to follow this simple step. Open OST file and choose Save to PST option then click on Convert Now button. It also convert OST file into other file format such as EML, EMLX, MBOX, HTML, vCal, vCard, MSG etc. In the free version of this software, you can convert 30 items from each folder for free. By using the trial version you can also check the performance of this software. It supports all the versions of Microsoft Windows & Outlook.
  • I will suggest you try OST to PST Converter developed by CoolUtils. This safely recovers all your important items like calendars, task, contacts etc. This software easily handle large files conversion too. You can read more about this here - https://www.coolutils.com/OSTtoPSTConverter
