Dux EDB to PST software
In my knowledge dux EDB to PST convert software is the best software. I used their software i feel how easy to convert EDB to PST file.
For more information please log on to :- https://www.duxdatarecovery.com/edb-to-pst-recovery.php
    You can also try Kernel for EDB to PST Converter software. It is very advanced and secure software to solve EDB corruption issues and convert them in accessible PSt formats. It also helps to recover deleted or inaccessible emails and other data from healthy as well as damaged EDb file. For more information, visit: https://www.nucleustechnologies.com/edb-to-pst.html
    Are you suffering from exchange EDB corruption then just download the SDR EDB to PST conversion software which smart tool for repair damage exchange EDB file data and convert Exchange mailbox data to PST along with EML, MSG, HTML, MHTML, TXT etc.
    READ MORE :- https://www.stelladatarecovery.com/
    Bitdataconversion for EDB to PST Converter is a wonderful tool to repair corrupted EDB files and convert EDB to PST files. It has another feature to export EDB data into Office 365, Live Exchange server, EML, and MSG. Get all the features in detail: https://shovivtools.wordpress.com/convert-edb-to-pst/
    EdbMails EDB to PST converter is reliable,efficient,accurate recovery tool for corrupted Exchange Database.It can recover all the information from even the most corrupt EDB file and convert it to Outlook PST.
    The tool is designed to recover all data items like mails,mail attachments,drafts,contacts,calendar,tasks,notes,journals etc of EDB without any data loss. It can export individual mailboxes/folders or entire database. The entire EDB can be examined and source files are not altered during migration. This process is made easier and flexible by allowing the user to specify the desired size to split recovered EDB into smaller chunks. The detail understanding of the export operation is logged and user can view it. Trial version of EdbMails EDB to PST converter is available for downloading,with all features and the export limited to 30 items of each file.
    Key Benefits of EdbMails EDB to PST converter
    1. Supports exchange server versions like 2019,2016,2013,2010,2007 and 2003 and most Windows operating systems including Windows 10.
    2. Maintains the folder structure intact
    3. Convert PUB.edb/PRIV.edb file to PST or migrate it to Office 365/Live Exchange Server.
    4. Repairs Larger size EDB files without data loss.
    Public folders is one of the most used features on premise Exchange Servers. With the granular level permission options that public folder allows for, it is easy to grant or deny access to users as one wishes. Public folder can be made available to everyone in the organization. The main purpose of public folder is to share common information to everyone in the organization. Public folder supports features like Contacts, Calendar, Notes, Journals etc. These features makes considerable improvement in growth of the
    organization. Business activities will be more streamlined and systematic. So restoring of Public folder is very important.
    There are many other scenarios which can corrupt the Exchange Database. System Failures such as Hardware , malicious software, human error etc can result in panic and potential data loss. Exchange Database will not mount and mailboxes will be inaccessible. In these scenarios, Exchange Database needs to be recovered at granular level.
    The only tool you need
    EdbMails EDB to PST converter is one of the efficient,reliable,flawless recovering tool. Apart from this, it allows user to migrate EDB mailboxes to Office 365 or Live Exchange Server. This tool ,by default does standard scan of EDB for recovery. If not able to recover,it allows user to choose Advanced Scan which can recover highly index corrupted EDB file. This tool is very user friendly and user does not need expert help for operating.
    Public Folder EDB data can be recovered and migrated to Office 365 or Live Exchange Server seamlessly, if need be, using EdbMails.
    Highlights of EdbMails EDB to PST converter.
    1. Efficiently extracts email items like Calendar,email attachment,emails, contacts, deleted items etc.
    2. Efficiently recovers both PUB.edb and PRIV.edb folders.
    3. Preview all your EDB contents before export operation.
    4. Maintains the folder hierarchy intact.
    5. There is no size limitation for recovering EDB file.
    6. User can specify desired size for exporting the EDB to PST.
    7. View of log is provided to understand the export operation.
    8. Very user friendly tool which can be used without expert attention.
    9. Supports exchange server versions like 2019,2016,2013,2010,2007 and 2003.
    10. Compatible with both 32 and 64 bit versions of Ms Windows.
