Atom TechSoft Outlook OST to PST Converter Tool-FREE DEMO Version
in General
To recover the data from damaged OST file I suggest you Atom TechSoft Outlook offline OST emails to PST Converter tool that is supportable to fix virus, errors of Outlook conversion/restore/export more than one file in a safe manner. Using it you can conversion/transfer your data smoothly and effortlessly into several interesting file formats such as PST, EML, EMLX, vCard, vCal, MSG, MBOX and HTML. It allows you to work in the absence of MS Outlook installation in your system. Before the conversion, you can see the preview of recovered mailbox along with emails, notes, deleted-items, drafts; outbox sent-items, contacts, inbox, and calendars. It gives 30 days money back guarantee.
More info-: https://gust.com/accelerators/ostrecovery
Get more the one solutions like OST file recovery, OST to PST conversion, restore deleted OST items, export OST to Office 365 etc. using one tool named OST to PST Converter from Bitdataconversion. This tool also provides a feature to save OST data into EML, MSG, HTML, RTF, Cal, vCal and vCard format. Read More https://shovivtools.wordpress.com/convert-ost-to-pst/
Much software also advises about transfer OST to PST Converter Tool. But a few days ago I had also faced that type of problem and I have used OST to PST Migration Software to successfully resolve my all OST to PST related difficulties. Get more information, visit from https://www.gaintools.com/ost/pst/
The OST To PST Converter Tool may be a solution of difficulties initiated by Exchange Server. In the event of Exchange Server downtime, unintentional user account deleted, the server crashes plus your data is not available, and you might need to convert the OST to PST file format. I will recommend you to use OST to PST Converter tool introduced by Coolutil. Download it from here - https://www.coolutils.com/OSTtoPSTConverter
With the assistance of OST to PST Converter software you can convert single as well as multiple files along with Emails, sent-items, deleted-items, drafts, outbox contacts, inbox, calendars, notes (To, Cc, Bcc, Subject, From, Object, Date and Time). This software has a split facility that gives you permission to split large OST file into several small PST files as per your need. Before finishing the conversion you can see the preview of recovered mailbox then restore the data into PST file format. http://www.toolsbaer.com/ost-to-pst-conversion/
There is no manual way to convert OST file to PST format but you can use some external software application to convert OST to PST format:
http://www.axblaze.com/products/osttopst-converter.html
For the conversion work task, you can try third-party tool like OST4 OST to PST Converter tool that easily exports single as well as multiple OST files along with emails, notes, contact, attachment, task, draft, inbox, journals and calendar etc. The users can save their data into many file formats like PST, EMLX, MSG, vCal, vCard, MBOX and EML with full accuracy. It provides 30 days money back guarantee if you are not happy with its work.
In case of any OST corruption issue like damage, corrupt, etc. then, I would like to suggest the OST2PST Wizard. This is the best utility to convert OST to PST file format only. It can safely transfer OST data into PST file without losing any data. And there is no confusion in OST to PST Converter for multiple file formats. It can especially to convert OST to PST file.
Read more info: OST to PST Converter
