How to Import PST to Office 365 Account?
If you are Import your PST file by using Manual method then you are wasting your Much time when you can also do this easily and fast. then why are wasting your time. So today I want to you suggest you try this Third party tool which is Regain PST to Office 365 Converter that can easily Convert your PST file to Office 365 in just few second. This Tool has many features which helps you lots. Outlook is not required to be installed on your system.
CheckOut this Software free demo version here:
http://www.psttooffice365migration.emltopstutility.com/
    Here you can use the Manual method or any third-party solution to convert the PST to Office 365 Mailbox. There are many applications available so I suggest you the best third-party software which is Softaken PST to Office 365 Migration Tool. With this application, you can easily convert your multiple PST files data like emails, contacts, calendars, appointments, and attachments etc into multiple Office 365 Exchange Online Mailbox account.
    There are two methods to import PST to Office 365 such as the Manual method and Third party tool. You can choose any one method to import your PST file into Office 365. However, I would suggest you go with a third party tool because it provides an easy and safe solution to import PST to Office 365, Live Exchange server, new PST, EML, and MSG.
    To import Outlook PST data you require MailsDaddy PST to Office 365 Migration Tool. I would like to recommend this software as it export bulk PST file to either primary or the archive mailbox of Office 365. This tool is very easy to handle. It has an advanced search option which allows you to search and add PST file very quickly. It also allows addition and transfer of a single PST file. It has the ability to move bulk PST data with or without impersonation. You can import PST data to o365 without the need of the PowerShell.
    vikashjivikashji
    edited September 2019
    If you search on the web, you will find many solutions for PST to Office 365 conversion and manual method. When I faced this problem, I used Bitacube Import PST to Office 365 Tool. This tool provides various advanced features to users which help technical or non-technical users, can import PST file directly into Office 365 mailbox with just a few clicks.
    Read More: http://bit.ly/2mgVUbx
    WholeClear PST to Office 365 converter is specifically made to provide instant results for importing PST files into Office 365 account. The software exports all mailbox items into Office 365. You can downolad free trial version available. The whole migration is done smoothly without affecting the data integrity.
    For more info: https://www.wholeclear.com/pst/office-365/
