Convert Lotus Notes to Outlook PST file 2016 & 2019
With the help of ATS NSF to PST Converter software supportable with all the version of Lotus Notes .0.1, 9.0, 8.5, 8.0.2, 7.0, 6.5 and 6.0. With the assistance of this utility, the user can divide their large OST file into PST files without creating any size limitations. With the help of this tool, you can convert single as well as multiple files. You can see the preview of recovered mailbox before the conversion process and convert into PST and another file formats such as EMLX, EML MBOX, MSG, HTML, CSV, vCard, vCal, Office 365 & Live Exchange Server.
More Info: https://www.bulkecommerce.com/store/nsf-to-pst-converter-153.html
  • As far as I know, users can convert their Lotus Notes data into Outlook using two methods 1. The Manual Method and 2. Automated method. Here I am going to share a blog post which helps to know about both methods. Read More
  • In Conversion process to convert Louts Notes database to Outlook PST file. I know their are two methods to convert NSF file to PST file.
    • Manual Methods
    • Automated Methods
    **Manual Methods: **
    • Run Open IBM Lotus Notes
    • Find the NSF files that you want to convert. Click “Open”
    • Go to the “File” option and click on “Export”
    • Browse and choose the point where you wish to save the files
    • Select the desired format in the “Save as type” option.
    • Assign a name to the file and choose “Export”
    In the next step, you are asked to choose how much data you want to export. If you want to export the entire database, you can do that. You can also choose individual files.
    Once you have chosen both, click OK
    See Blog:
    Automated Methods
    We provide the best NSF to PST Converter tool to extract the data from Lotus Notes email client to Outlook client and to do that there is no need to have any technical skills to operate this application. It successfully converts email, inbox, outbox, contacts, deleted items, drafts, calendars, sent items, notes (to, cc, Bcc, subject, date and time) into PST without causing the alteration in the original structure. You can split your large NSF file into several small PST file according to your requirement. The user exports their data into several interesting file formats such as PST, EMLX, MSG, HTML, CSV, Office 365, MBOX, Live Exchange Server, vCard, and EML
    More info Visit: https://www.inquitsoftware.com/en/nsf-to-pst-converter.html
  • You can also try to use NSF to PST Conversion Tool, this software convert NSF files created with Lotus Notes clients to MS Outlook PST files. You can get this software from here: https://www.gaintools.com/nsf/pst/
  • You can either try manual method, or opt for a professional SysInfo NSF to PST Converter tool to convert Lotus Notes emails to PST.
  • A long time ago, I faced the same problem and I used many manual methods but they all were too lengthy and complex. Then I used NSF to PST Converter and got an instant solution to my problem. So, I would suggest you use NSF to PST Converter rather than searching for solutions and testing these methods.
    For More Information Please Visit:- http://www.osttopstapp.com/nsf-to-pst.html
  • The simplest way to convert Lotus Notes to Outlook PST file of any version (whether 2016 or 2019) is by using the tool like eSoftTools NSF to PST Converter Software. It lets the user recover the information of IBM Lotus Notes in various file formats such as PST, EML, EMLX, HTML and many more. Apart from conversion, it provides the option to split PST files into many PST files for free. It previews each and every step of working to the user for their acknowledgment. All the variants of IBM Lotus Notes work well with this tool.
    Explore more: http://www.esofttools.com/nsf-to-pst-converter.html
  • Here is a Software that can easily convert NSF file to PST file.
    Try this Software free demo version from here:
    http://www.nsftopstconverter.emltopstutility.com/
  • demetriodemetrio
    edited March 2019
    If you are going to convert Lotus Notes to PST then you can opt Total WebMail Converter. This tool is developed by Coolutils. This tool receives all emails directly from POP3 accounts and converts them to PDF, DOC, TIFF, TXT etc..
    Features
    1. Maintaining is easy
    2. Conversion takes seconds.
    3. Generate Report
    4. Pro version can also convert attachments.
    Official Website -
    https://www.coolutils.com/TotalWebMailConverter
    Hope it helps!!
  • If you want to convert Lotus Notes NSF to PST Outlook, So Shoviv NSF to PST Converter software is another effective solution to migrate your NSF files to PST without any interruption. It migrates unlimited mailboxes from Lotus Notes NSF to PST Outlook, EML, and MSG in a single attempt. It supports all the Microsoft Windows Operating systems and Outlook versions. It provides the free trial version of this tool which helps you can convert the first 25 items per folders.
    Get more details, visit:- https://how-to-convert-nsf-to-pst.blogspot.com/2019/01/how-to-convert-lotus-notes-to-outlook.html
    Get more details, visit:- https://techno-miky.blogspot.com/2019/01/how-to-convert-lotus-notes-to-outlook.html
  • The easy and safe way to convert Lotus Notes to Outlook PST of any version (2016 or 2019) is by using an NSF to PST Converter software. It can easily export NSF file to Outlook PST format including all attachments.
    Advanced Features of NSF to PST Converter
    • Convert NSF file to Multiple file formats like PST, EML, MSG, etc.
    • Import NSF file to Office 365 and a Live Exchange Server directly.
    • Convert NSF file to PST even without installing the MS Outlook.
    • Retain Metadata and Properties.
    • Free Preview of NSF files.
    Download for free: http://www.nsf-converter.com/
  • Are you unable to find the best solution to convert NSF file to PST file format ..? Do not worry, I would like to suggest here one of the best and reliable tools such as Bitacube NSF to PST converter. This device provides various features such as:
    • It supports MS Outlook (32 bit & 64 bit) 2016/2013/2010/2007 and all the below versions.
    • It is compatible with Windows 10, 8.1, 8, 7, Win-XP and all the earlier versions.
    • It supports Lotus Notes versions 9.0.1, 9.0, 8.5, 8.0.2, 7.0, 6.5, 6.0 and, 5.0.
    • It allows you to save converted items in PST, EMLX, MBOX, MSG, HTML, CSV, vCard, EML formats.
    • Export Lotus Notes data into Office 365 and lives Exchange server.
    • It provides 24*7 technical support which provides genuine assistance in any problems related to this software.
      You can check here this tool free trial version: https://www.bitacube.com/nsf-to-pst-converter.html
  • By taking the help of MailsDaddy NSF to PST Converter tool, one can easily export NSF emails, contacts, calendars, tasks, notes, etc. in PST format without losing a single data item. The tool is well-coded for an effective and efficient Lotus Notes to Outlook Migration without getting any trouble. It supports IBM Notes and MS Outlook email client to execute an error-free process to convert NSF to PST. Download this utility in Windows OS-compatible machine and get a quick and error-free result in Outlook PST file format which is importable in Outlook 2019, 2016, 2013, etc.
  • I would like to suggest use Lotus Notes to Outlook Converter tool to export complete Lotus Notes mailbox data in Outlook without losing a single data item. It converts multiple NSF files at a time with the same email properties, folder hierarchy, text formatting, and HTML formatting.
