Suggest the Best MBOX to PST Converter
When we are looking for best MBOX to PST Converter, I will recommend you to choose only ZOOK MBOX to PST Converter.
It is one of the best and the trustworthy solution to export multiple MBOX files into PST format. The tool has multiple advance features to save MBOX files as PST format in few seconds.
Just follow simple steps: -
  • Install and Launch MBOX to PST Converter.
  • Choose MBOX Files/Folder.
  • Click on Convert.
In couple of seconds, the tool converts all your selected MBOX files to PST format.
For More Info: - https://gallery.technet.microsoft.com/MBOX-to-PST-Converter-aaa53ecb
«1
    edited December 2018
    In my suggestion, you can try a manual method to convert MBOX to PST format. But, as you are looking for the best MBOX to PST Converter, then I would suggest you try MBOX to PST converter from Bitdataconversion because It has a free trial version which helps users to know its working process and features. Read this Blog to know more: https://mboxtooutlookpst.weebly.com/
    There is no such Mac MBOX to PST Converter that is free of cost. Yes, free versions are available but have some limited features over purchased Softwares. Here I want you to refer MBOX Converter to export your MBOX file into Outlook. The free version of the tool can export some of your emails to PST. You can also purchase the software from the official site. Visit here to download the free version:-https://www.toolscrunch.com/mac-mbox-to-pst-converter.html
    In my suggestion, you can try a manual method to convert MBOX to PST format. But, as you are Outlook for the best MBOX to PST Converter, then I would suggest you try MBOX to PST converter because It has a free trial version which helps users to know its working process and features.
    Visit at ; http://www.softwaretoconvert.com/mbox-to-pst/
    Sometimes users require migrating MBOX file to PST format in such situation MBOX to PST Convert Utility is the ideal explanation. You can easily convert MBOX file to PST, MSG, and EML formats without the required of any other application. The software supports many other different email clients like Thunderbird, Eudora, Opera Mail, etc and provides a perfect user interface, so understand and work with a tool is not a difficult task. Split option is also helpful if the user has the large size of the file. For More Information: https://www.sametools.com/convert/mbox/
    If you want to convert your MBOX file to PST file, I highly recommend KDETools MBOX to PST Converter. MBOX to PST Converter tool is the ultimate solution for converting your MBOX files into Outlook PST file. You can easily transfer your MBOX file into Outlook PST file by KDETools MBOX to PST Converter.
    The software has advanced features to save MBOX files as PST file format in few seconds. By using this software you can save MBOX emails into multiple file formats like PST, PDF, MSG, MBOX, EML, and EMLX etc.
    This software supports all the versions of Microsoft Outlook and Windows. It can convert Gmail to MBOX file format. It can convert the complete date of MBOX and include this mail data, folder, and subfolder, attachments, address, task, journals & other components of the mailbox.
    With the help of this software or tool, you can quickly import the meta properties of mail properties like To, CC, Bcc, send and receive data of an email, sender details, time, the subject of email and attachment etc.
    https://www.kdetools.com/mbox-to-pst-converter.html
    By using a MBOX to PST Converter software like Kernel for MBOX to PST Converter, you can easily and quickly convert MBOX/MBX/MBS/MSF files to Outlook PST formats without facing any issues. To know more about the software, visit: https://www.nucleustechnologies.com/blog/import-mbox-emails-to-ms-outlook-2016-and-2013/
    You can also use VOOK MBOX to PST Converter to export multiple MBOX files into PST format at once. It has so simple Interface which lets you to perform quick and simple MBOX to PST Conversion without losing any data items.
    Regain MBOX to PST Converter utility integrated with strong algorithm and it is efficient to convert all data to pst format along with attachment, images, all available meta data into your emails.
    Try this tool free demo version from here:
    http://www.regainsoftware.com/mbox-to-pst-converter.html
    A secure exportation from MBOX to Outlook is depending on reliable & accurate method. So we suggest MailsDaddy Thunderbird to Outlook converter, which is fully effective and quick responsive application to import MBOX data in Outlook PST format. With this tool, you can extract the valuable email using filter option and export it into PST, HTML. MSG, MHTML, EML, RTF formats. The software is capable to preserve folder structure, rich text and attachments after converting MBOX to PST format.
    for more detail visit here: https://www.mailsdaddy.com/mbox-to-pst-converter/
    KDETools Software is one of the best software company. MBOX to PST converter is the best converter used for converting MBOX file to PST file format. Thunderbird to Outlook Converter tool also export Multiple MBOX file into PST, PDF, EML, MSG, EMLx, HTML etc. MBOX to PST Converter tool supports Thunderbird, Apple Mail, Mozilla Mail etc.
    You can use MBOX To PST Converter Tool to convert MBOX to PST. This is a 100% safe and secure conversion tool for you. MBOX to PST converter migrates MBOX files from email clients like Thunderbird, AppleMail, Eudora, Mulberry, SeaMonkey, Opera Mail, Mozilla Mail, into PST file format.
    Now every user has a chance to solve all MBOX corruption problems by using ATS MBOX File Recovery Software. This application helps to eliminate all error of MBOX file and migrate into PST files without any defaults. Using this tool, users get the easy process of doing recovery MBOX data and Migrate MBOX to Outlook PST Files and other formats like EML, MSG, HTML, EMLX and vCard with accuracy. Its program also supports Windows 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit). This is a special utility that exactly removes all fallacy to repair damage MBOX File and move every MBOX Data into PST File without distress.
    Read More Info: https://www.bulkecommerce.com/store/ats-mbox-to-pst-converter-171.html
    If you are finding a best MBOX to PST converter for moving MBOX files to PST format, then I would like to suggest Indya MBOX to PST converter. This the best tool for converting MBOX emails to PST and import into Outlook 2019, 2016, 2013, 2010, etc. It comes with numerous features and the best feature of this is bulk file conversion. The tool allows you to transfer multiple MBOX files to Outlook PST in a single time. It fully compatible with all MBOX supportive email clients for conversion such as Thunderbird, Apple Mail, Entourage, Opera Mail, Netscape, etc.
    if you are looking best mbox to pst converter software so I would like to you suggest one of the best mbox to pst converter software this software is export all mbox item and recover smoothly and convert without any data changes and loss by using this software you can convert mbox file into multiple file formats like MSG HTML PDF PST EMLX etc it supports all ms outlook versions
    There are various software available in the market to convert MBOX to PST, I will suggest you to use Coolutils MBOX to PST Converter tool. The reason to recommend you this tool is that they are providing their service since 2007 and you can rely on them. Apart from this tool has friendly UI and a non-techy guy can use it easily.
    You can download it from here - https://www.coolutils.com/TotalMailConverter
    If you are looking best software of MBOX to PST Converter then try** KDETools MBOX to PST conversion tool**. By using this software you can easily convert MBOX emails to PST format. This tool supports all MBOX supportive email clients like Thunderbird, Apple Mail, Entourage, etc. It is capable to export PocoMail emails to PST including all attachments. Non-technical users can also use this software. It comes up with a friendly user interface that is the best part features of this utility.
    Get third party MBOX to PST converter to convert MBOX file to Outlook PST format. Suggested tool has ability to convert MBOX to PST and other file type by which you will be able to access MBOX file contents via any email platform.
    Visit: http://www.axblaze.com/products/mboxtopst-converter.html
    I read your problem and come to know that you want a software that simply converters your MBOX to PST format without any data loss. I would like to suggest you MBOX to PST Converter.
    You can try this:- [http://www.toolsbaer.com/mbox-to-pst-conversion/]
    Hmm... An MBOX to PST conversion software that is potentially the best among its counterparts?
    I was going to give a list of some that I found quite useful (while trying out the demo versions), but it seems people have already covered most of them. Although one seriously top contenders (as per my experience) are still missing from this list - SysTools MBOX Converter.
    I still have a copy of this excellent software to dish out PST files to all my clients who require data in Outlook supported format. And not once have I received any complaints about missing emails, attachments, formatting or anything of that sort.
    The free trial is available here: https://systoolsgroup.com/mbox-to-outlook-converter.html
    The rest is your choice. Hopefully, it will help you the same way it has been doing for me.
    edited June 2019
    I would like to suggest you a professional tool for MBOX to PST Conversion, which is well known as SysBud MBOX to PST Converter. The MBOX to PST converter is equipped with features, like:-
    • Batch conversion of MBOX files to PST file format
    • The software can convert multiple MBOX files in single or separate PST file format
    • It supports more than 25 MBOX based email clients.
    • Compatible with Outlook 2016, 2013, 2010, 2007, 2003, etc.
    edited June 2019
    Nowadays, MS Outlook is highly demanding and secure desktop email client. It is available with more features and functionalities, that’s why most of the users migrating from other email clients like Thunderbird, Apple Mail, Webmail, Eudora, Poco Mail, Opera Mail to MS Outlook. MS Outlook supports only the PST file format to use external mailbox with same profile and same platform.
    All the above mentioned email clients except to MS Outlook, support only MBOX, MBX, or MBS file to save the mailbox data. To migrate from these email clients to MS Outlook, I am suggesting to convert MBOX file to PST file format. Try _MailsSoftware MBOX to PST Converter _tool to export MBOX data to Outlook compatible PST file format along with complete emails and attachments. For more information, you can visit the official website.
    Try CoolUtils Total Mail Converter, helps you to manage your emails outside of your email client. This will help you to convert MSG or EML to PDF, DOC, XLS, PSG etc.
    You can call them over phone at +1 (855) 418-2323. You can find more about the tool here - https://www.coolutils.com/TotalMailConverter
    Total Thunderbird Converter converts emails from Mozilla's Thunbderbird e-mail client to PDF, DOC (WORD), HTML, TXT, TIFF, and PST in batch. Whether you need to safely archive your correspondence in PDF, or migrate emails to Outlook, our converter is up to the task providing you with fast, accurate conversion options.easy-to-use app is able to automatically connect to your Thunderbird client and suggest emails for conversion or you can import MBOX files. https://www.coolutils.com/TotalThunderbirdConverter
    edited July 2019
    I suggest you the best converter to convert the MBOX files to PST file with the help of this Software. This software contains lots of features Such as its convert the file into multiple file formats like HTML, EML, EMLX, MSG, etc
    The mbox file supports 20+ Email Clients such as Thunderbird, Entourage , Eudora, Apple Mail, Opera, etc .
    Click Here: http://www.mboxmails.com/
    One of the most reliable software for MBOX To PST conversion is here which will offer batch conversion of MBOX files.
    • Answer MBOX mailbox corruptions issues.
    • Imports large MBOX files without any interruptions.
    • Export .mbox files into .msg, .pst, msg, & etc.
      To know more about the tool Click on the link mentioned below.
    https://mailconvertertools.com/mbox/
    Use MailsDaddy MBOX to PST converter this is the best GUI based application that easily exports single or multiple mailbox data to Outlook PST format. The tool has lot of useful features that help in transferring MBOX to PST format.
    Features:
    • Mail filter
    • Save select email in MSG, HTML, MHTML format
    • Preview
    • Bulk migration
    • Support all Window and Outlook versions etc.
    If you are looking for a fast and easy way to convert MBOX file to PST format, then you should check out any proficient third-party tool. I had faced this problem even a month ago when I used Bitacube MBOX to PST Converter. This tool provided me with various advanced features which enabled me to convert various NSF file into PST format without any hassle.
    Read More: https://www.bitacube.com/mbox-to-pst-converter.html
    If you want to convert the MBOX data into Outlook PST file format, then try the best MBOX to PST software. The tool has a simple and modern UI that quickly allows you to convert multiple MBOX files to Outlook PST file format. The tool provides 100% secure and reliable MBOX to PST conversion. The tool supports large size MBOX files.
    For more information visit: http://www.syscurve.com/mbox-to-pst-converter.html
    Check out the Mail Extractor Pro to convert your MBOX to PST. It comes with in-built file splitter and support and maintain file hierarchy for your conversion. It has very easy to use interface.
    For more info: https://mailextractorpro.com/mbox-to-pst-converter-free/
    The conversion of MBOX to PST is a very difficult task for all users who are migrating MBOX file data to PST with the help of the manual method. It is a complex and time-consuming process, if you are a non-technical user, then you can increase the chances of losing important data of the MBOX file. You can complete this task without any hassle with the help of any proficient third-party tool such as Bitacube MBOX to PST Converter which complete scan the corrupt MBOX file for error and recover, it very fast and also save their MBOX file into PST, MSG, EML, HTML and RTF formats.
    You can check here this tool free trial version: https://bitacube.com/mbox-to-pst-converter.html
