What is the easy way for converting OST to PST file?
A few days ago my OST file is get damaged then I need an easy conversion tool under 50$. I have no technical skills for converting the data from OST to PST so please suggest the best way for the conversion
  • By taking the help of OST to PST Converter tool the user convert single as well as multiple files at a onetime along with emails, sent-items, deleted-items, drafts, outbox contacts, inbox, calendars, notes (To, Cc, From, Object, Subject, Date, Bcc and Time). Before the actual conversion shows the preview of recovered mailbox before the actual conversion. The user split their large files into several small PST files as per their need. In the free demo version, it allows you to convert 30 emails into PST, HTML, EMLX, EML, vCal, MBOX, vCard and MSG file formats free of cost.
    Read More Info: OST To PST Converter
  • One more solution names Bitdataconversion OST to PST Converter software which can you use for converting OST to PST files. This tool also helps to export OST to Office 365, Live Exchange server, EML, and MSG.
    Read this blog to know more: https://shovivtools.wordpress.com/convert-ost-to-pst/
  • Moreover, you might not be capable to export everything from OST to Outlook PST. So, it’s better to opt for an alternate explanation. You can try OST to PST Migration Software for this conversion process. It will help you to transfer all your OST data in Outlook file format without any data loss.
    There are various easy methods to convert OST file to PST format. If you want to switch OST to PST file manually, you can go for the procedures. Read more:
    https://www.sametools.com/convert/ost/
  • Kernel for OST to PST Converter software is an easy solution to move Outlook OST file in PST formats. The software also allows you to solve OST corruption and recover all stored data within few clicks. To know more about the software, visit: https://www.nucleustechnologies.com/supportcenter/kb/ost-to-pst-converter-full-version
  • Download this tool free demo version and convert OST file to PST file.
    from here:
    https://download.cnet.com/Regain-OST-to-PST/3000-2367_4-77435711.html
  • According to our experience you can try this OST to PST converter Software. You can easy way to convert your .ost file into .pst file. if you any doubt then you can try it free demo version.
  • Stella OST Recovery software to a best easy way for converting OST to PST file into several formats like as: PST, EML, MSG, HTML and outlook profile etc with full accuracy. Through Stella tool, you can use easily migrate email from exchange offline OST file to PST file outlook 97 to 2019 with all previous data.
    For More Details Search on Google: Stella OST to PST Software
  • OST to PST Recovery Software has been designed by Inspire Data Care. It has tons capability to get better corrupted, broken or inaccessible OST file into PST document formats inside few minutes without any lack of statistics. Also recover OST document into extra formats like EML, MSG, MBOX, PDF, and HTML. This software program also consists of advance functions like import OST file into Office 365. This software program helps home windows up to ten and all Microsoft Outlook variations like ninety seven, 2000, 2003, 2007, 2010, 2013, 2016 and 2019.
    Click Here for free version - https://inspire-ost-to-pst-converter-software.en.softonic.com/download#
  • If you want to change a computer and still wants to use your exchange mailbox without exchange connection, you need to export mailbox to PST format and you can then open PST files on your new computer for mailbox view. For export, you may use OST file exporter which safely **export all OST files to PST **without changing their structure and any loss.
    Visit here more info: http://www.outlookconverter.net/ost-to-pst/
  • There are two ways to convert OST to PST.
    First: If you are connected to Exchange Server
    1. Click File, then click Open & Export
    2. Click Import/Export to open Import and Export Wizard
    3. Select Export to a file, and click Next.
    4. Select Outlook Data file (.pst) and click Next
    5. Select the folder (.OST file) that you want to export from, then click Next
    6. Select the path where you want to put the new PST file. Click Finish.
    Second: If you are not connected to MS Exchange Server
    Use external software application: http://www.axblaze.com/products/osttopst-converter.html
  • Using Microsoft OST to PST converter by KDETools is the most easy way to convert OST file to PST format. Just follow these simple steps to convert OST file to PST format.
    1. Open KDETools OST to PST Converter.
    2. Choose OST files.
    3. Click on "Export" button
    4. Choose "Save to PST" options.
    5. Click on "Convert Now" button.
  • Hi, if you want to perform OST to PST Conversion process then There are two ways to perform this task. The first one is the manual way by taking the help of the Import / Export Wizard of Outlook Application. But there are some limitations to this manual method. Like in case if you have a corrupted or orphaned OST file then you cannot perform the conversion process. So, in that case, it's better to take the help of OST file to PST Converter application.
    I found an informative article for you to which explains the OST to PST Conversion process easily. For complete details please refer to this: https://www.dataforensics.org/two-freeware-solutions-to-convert-ost-to-pst-file/
