Best MBOX to PST Converter ?
Suggest me how to convert MBOX file to PST file format. please help me.
    I would like to suggest MBOX to Outlook converter. It is specially performed for more than 30 MBOX based email client to Outlook migration such as Apple Mail to Outlook, Thunderbird to Outlook, Netscape to Outlook, Entourage to Outlook, SeaMonkey to Outlook etc. The software also keeps same folder structure, Message Body, meta data & attachments after converting MBOX to PST.
    Visit at ; https://www.tooltoconvert.com/mboxtopst.html
    valedinavaledina
    edited February 2019
    Mac MBOX to PST Converter provides the solution to import MBOX file to PST other file formats without corrupting any of data. The utility export MBOX emails along with attachments. It allows bulk conversion to save time and energy. It gives multiple file naming options to save PST file as per the requirement. It has the search option to search particular MBOX files easily. The tool is compatible with all the versions of Mac OS. With this converter, you can store resultant file to the desired path. Visit here for info:- https://www.toolscrunch.com/mac-mbox-to-pst-converter.html
    MBOX to PST Conversion is a process of migrating MBOX files to Outlook PST format. For making the process more easier, take the help of a software which converts MBOX file that formally supports many email clients like Thunderbird, Apple Mail, Windows Live Mail etc into Outlook file. Conversion is not a very easy task for the users and the system administrators when performed by the manual way but MBOX to PST Converter makes the MBOX conversion safer. This Software supports the recovery of data from MBOX file and saves it into the new file. Also, supports batch Conversion of MBOX to PST file in no time.
    hanahhanah
    To convert MBOX to PST, there are many ways possible. The manual solution is not practical for a user who does not have much in-depth knowledge about the two file formats i.e. MBOX and PST. MBOX is a single file storing all email messages in a concatenated format. It is generally supported by email clients like Mozilla Thunderbird, Apple Mail, SeaMonkey, etc.
    Google Gmail MBOX converter is an appropriate solution to export Google MBOX to Outlook PST in a quick, secure and simple way.
    I would like to suggest MBOX to PST converter from Shoviv that can easily convert MBOX files into PST format and support 20 other email clients which support MBOX file format such as Thunderbird, Eudora, Spicebird, Seamonkey etc. Using Shoviv MBOX converter users also export MBOX to Office 365 server and Live Exchange server. The tool supports all version of Groupwise and outlook as well.
    If you are looking convert MBOX to Outlook PST then I would like to suggest you to best MBOX to PST converter software. which is KDETools MBOX to PST conversion tool. By using this software you can easily and quickly convert MBOX to PST file within few clicks. It can import MBOX to outlook instantly and convert PST formats without any data changes. It supports all MS Outlook versions.
    You can use Total Mail Converter Tool introduced by CoolUtils. This tool manages your all emails from outside the email client. You can convert EML/MSG to TIFF, XLS, XPS, TXT, etc.
    This tool is 100% clean and easy to use. It comes with Free and Paid version, I will suggest you to use free first. Download it from here - https://www.coolutils.com/TotalMailConverter
    Try third party MBOX to PST Conversion software and easily convert MBOX data in Outlook PST format. Read more information and free download click here http://www.mboxtopst.n.nu
    Best MBOX to PST converter is recognized by its efficiency to convert Outlook PST file, Recovery rate, data structure, compatibility, migration process and other effective points. The one tool that stands as the best MBOX to PST converter is from MailsDaddy. You can easily download the software, its simple and user-friendly interface quickly converts your valuable data in PST format.
    edited August 2019
    If you want to export your multiple or huge MBOX file to PST file format, you should try SysBud MBOX to PST Converter. This single wizard application swiftly exports multiple MBOX files into single & different PST file.
    Key features of MBOX to PST Converter software:-
    1:- Supports more than 30 MBOX based clients like- Apple Mail, Pocomail, Sparrow Mail, Netscape, Claws Mail, SeaMonkey, Opera Mail, etc.
    2:- No file size limitation in this software.
    3:- Saves resultant PST files at the required location.
    4:- Compatible with all MS Outlook editions like- Outlook 2003, 2007, 2010, 2013, 2016,2019, etc.
    5:- Allows user to use the free Demo Version and transfer 25 emails per folder at free of cost from MBOX to PST.
    If you looking for the best MBOX to PST Converter software then you can try MailsSoftware MBOX to PST Converter. It is the best solution to convert MBOX to PST. It has a simple GUI, which means anyone can easily operate the software without any technical support and advanced knowledge. The software provides a free demo version for the user that export first 20 MBOX emails from each folder to Outlook PST Format.
    I am going to suggest one of the Greatest tool named WholeClear MBOX to PST Converter Tool. If you use to this software for Converting your files so you can simply Convert MBOX to PST files format. This tool support all version like this:- 2000,2007,2008,2013, and 2016 etc.
    Visit here: https://www.wholeclear.com/mbox/pst/
    I would like to suggest here Bitacube MBOX to PST Converter tool. This tool provides you an advanced mechanism to convert the MBOX file into PST format without any hassle. It provides many features such as –
    • It scans all MBOX files at one time.
    • Supports multiple MBOX files of any email client.
    • Compatible with Thunderbird and Postbox MBOX data file.
    • Exports MBOX to PST files without altering the original data.
    • Converts MBOX to EML, EMLX, RTF, MHTML, and HTML format.
    • Provides naming convention option to save emails.
    • Compatible with all Windows operating systems.
    • Support Unicode & ANSI PST files to get email data accessible in any Outlook PST.
      You can check here this tool free trial version: https://bitacube.com/mbox-to-pst-converter.html
    Mac Mail to Outlook PST Conversion was never so easy. The ultimate tool Mail Extractor Pro does it all for you. It converts, conserves and present you an exact replica of the input file. Yes, a single tool does it all.Mail Extractor Pro offers you the best in class accuracy, precision and power to make sure that you won’t face any problem whatsoever. The accuracy of the tool is such that irrespective of the encoding scheme of the data, the tool converts all of it.So, be it ASCII or Unicode the tool converts all of it. This solves the problem of incomplete conversion process and gives complete security to your data. The precision of the tool is such that it even retains the folder hierarchy of the input file to produce an output file which is an exact replica of the input file.
    You can try it out from here: https://www.uslsoftware.com/mbox-to-pst-converter-for-mac/
    DataHelp MBOX to PST Converter is the best MBOX to PST Converter Tool ever designed. The software converts MBOX files to PST within a few simple clicks and comprises so many advance features. Everyone who wants to convert MBOX to PST file format must give it a try.
    You can search the best MBOX to PST then, I suggest MBOXmails MBOX Converter. This software easily convert MBOX to PST and multiple file formats such as EML, EMLX, HTML, PDF, MSG and, etc. MBOX to PST Converter is a very helpful solution for users to import MBOX mail to PST in bulk mode at one time without losing any data with email items. This software supports more than 20 MBOX based email clients such as Thunderbird, Sea Monkey, Opera Mail, Apple Mail and etc. This software supports all latest version of Windows and MS Outlook
    **Read More: ** https://gust.com/programs/how-to-move-mbox-to-pst-file-format
    cathelinecatheline
    edited January 2020
    If you have troubled to convert your MBOX files then I would like to tell you the most reliable and user-friendly MBOX to PST Converter tool. Last few days I also suffered from this type of problem then I have used this converter tool and also suggest to you. It can convert your multiple files into a single PST format without loss of your personnel data. It can save your PST file according to you. I highly recommend this tool because it supports 20 email clients for MBOX file format like Apple Mail, Gmail, Thunderbird, Eudora, Seamonkey, Opera Mail, etc.
    For more info about this tool kindly visit here
    edited April 2020
    Convert MBOX file to PST, DBX, MSG and EML, one caKernel for MBOX to PST converter software. It also allows you to save MBOX file on the Exchange server, Domino, Office 365, AOL, etc. Free trial version of the software is also available to download. To get the software complete step by step procedure, visit- https://www.nucleustechnologies.com/blog/best-practices-to-open-mbox-file-in-outlook-2016/
