How to Import Windows Live Mail to Outlook 2019
Use EML to PST Converter in order to import Windows Live Mail to Outlook 2019, 2016, 2013, 2010, 2007 and other versions. This tool convert emails from EML to PST along with all attachments. It has ability to import multiple EML files into PST without losing data quality and formatting.
Steps to Import Emails
  • Download and launch the tool
  • Select EML files
  • Select PST format from the saving options
  • Click convert button to start the process
  • leo013leo013
    edited December 2018
    If you want the easiest way to convert all EML files of different email clients like Windows Live Mail, Apple Mail, Outlook Express, Mozilla Thunderbird to Outlook PST file format, manually convert EML file to PST format for Mac. This post step by step guide to convert EML files to MS Outlook PST format in Mac. Using this solution, you can easily fix all types of corruption issue occur in EML file and it also gives the accurate conversion result. To download the free version of Mac EML to PST Converter:- https://www.toolscrunch.com/mac-eml-to-pst-converter.html
  • Get helps how to import windows live mail calendar to MS outlook 2019 and also support other PST file version as:- 97, 98, 2000, 2003 and 2016. **Stella free live mail calendar recovery software **allows to save 25 recovered Live mail calendar items to PST under demo which able free of cost.
    More Info: https://www.stelladatarecovery.com/live-mail-calendar-converter.html
  • If you want to try a manual method for data transfer from Windows Live Mail to Outlook then it will take more to you and there is some risk of data loss. So, you can try third-party software who will completely move to your file from EML to PST format without any risk and quickly. If you are searching any tool then I will suggest you EML to PST Conversion Software who safest and cool way to data migrate. With the help of this application, you can import Windows Live mail data in Outlook 2007, 2010, 2013, 2016, and 2019. Download link:
    https://www.sametools.com/convert/eml/
  • Get the simplest method and simple tool for migrating EML files and make them accessible by converting them to PST format. The tool is designed to meet the user requirements. You can easily avail a free version of the software. It does not matter for conversion whether Outlook is installed in your system or not.
    For more info: http://www.outlookconverter.net/eml-to-pst/
  • edited August 2019
    With the help of SDR Windows Live calendar conversion that more than capable to scan live mail calendar items and convert your live mail calendar .edb file into PST without any risk of data loss. This tool export Live mail calendar file to PST with vCal, CSV, TXT, ICS and HTML
    Read more:- https://www.stelladatarecovery.com/live-mail-calendar-converter.html
  • If you want to import Windows Live Mails email data into Outlook 2019 then, you should use Shoviv EML Converter tool that can easily convert multiple Windows Live Mail (EML files) into Outlook PST format without any technical assistance. Once the tool converts Windows Live Mail files into PST format, you easily import converted PST files into Outlook. The tool is comfortable for all type of user either they expert or beginner in technical knowledge. Its simplified user interface makes the conversion task easier and more precise. The tool also offers a free trial version which converts first 25 items for each folder.
    For more info visit here: https://gallery.technet.microsoft.com/Best-EML-to-PST-converter-fc297edf
  • You need a efficient tool that preserves all folder hierarchy and rich text formatting during Windows Live Mail to Outlook migration. I would like to suggest MailsDaddy EML to PST Converter to export single or multiple Window Live Mail to Outlook PST. This tool supports more than 10 email clients mailboxes and allows converting Window Live Mail data to Outlook MSG, PST, HTML, MHTML, EMLX & RTF format. User can install and run the tool on Window based operating system and perform the conversion for Outlook 2019, 2016 & others.
  • If you want to convert Windows Live Mail data to MS Outlook PST format, I recommend using DotStella Window Live Mail Converter. It is the best solution to export WLM data in PST format. It simply exports all EML data to Outlook with the full database in a single click. It is compatible with all versions of MS Outlook and Windows OS.
  • Hi, if you are looking for solution to import Windows Live Mails to Outlook then I found an informative article for you. It explains the best possible methods to perform this task. For complete info please refer here. https://www.softwarepro.org/blog/import-windows-live-mail-emails-to-outlook-2019-2016-2013-2010/
  • In order to import Windows Live Mail to Outlook 2019, no worries, many conversion utilities available online. In case you have Windows Live Mail application and want a direct conversion then you can go with Windows Live Mail Converter. Besides direct conversion, you can use the tool to load Windows Live Mail associated files manually for conversion. The application helps to import large number of Windows Live Mail files into MS Outlook. Apart from Outlook PST, the software also allows to import Windows Live Mail to PST, PDF, MSG, EML, MBOX, Thunderbird, Zimbra, Office 365, Exchange, Gmail, G Suite and more. Try the free demo of the tool now to analyse and understand software working.
  • edited April 2020
    To Import Windows Live Mail to Outlook 2019, I would like to refer an excellent third party software, Kernel for EML to PST. Its free version is also available to download. To know about its functionalities, follow the given instruction at- https://www.nucleustechnologies.com/blog/import-eml-to-outlook-2019-2016-2010/
  • Hi
    If you want a solution to import Windows Live Mail to Outlook, then you can try Windows Live Mail Migration Tool. A new launched app with lot of amazing features and user-friendly environment. In few simple clicks, all the data will successfully move from Windows Live Mail to Outlook with emails, contacts, calendar, tasks, notes and other items. You can test the working of Windows Live Mail Migration Tool by downloading the free demo edition that allows to migrate first 25 files per WLM item free of cost.
  • I would like to suggest EML to PST Converter to move Windows Live Mail data to Outlook. The tool support batch conversion of EML files into Outlook 2019, 2016, 2013, 2010, 2007 and 2003. It has simple and non-tricky working structure which makes the conversion so simple. The software maintains all mail properties accurately even after conversion. EML to PST Converter saves all type of attachments accurately without any difficulty. To get more info, download demo edition of EML to PST Converter.
    https://www.softspire.com/eml-to-pst.html
