Unable to Install Hololens Emulator. Error: Please install Visual Studio 2015 with Update 1 and UWP1
I am struggling to setup Hololens Emulator in my PC.
System Specs:
**> Windows10 Pro
8 GB Primary Memory
Intel i7 Processor
Hyper-V is enabled
Virtualization is Enabled in the BIOS
I have disabled the firewall and windows defender**
I am referring this link to setup the development for hololens development.
https://developer.microsoft.com/en-us/windows/mixed-reality/install_the_tools
I have successfully installed Visual Studio 2017 , the problem arises when I try to install the hololens emulator (build 10.0.14393.0) and it will fail, because the setup expects Visual Studio 2015 Update 1.
This is the short text:
Please install Visual Studio 2015 with Update 1 and UWP tools version 1.2, then run setup again.
Note: I unsuccessfully tried to setup every update of Visual Studio 2015 (1/2/3) all the community editions but they all gave me a "Stopped Working error". I even tried with ISO versions and the result is equivalent.
Here is a snapshot of the system log:
MSI (s) (10:E8) [10:15:31:257]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\DevDiv\Servicing\14.0\core 3: 2
MSI (s) (10:E8) [10:15:31:257]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (s) (10:E8) [10:15:31:257]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Wow6432Node\Microsoft\DevDiv\Servicing\14.0\core 3: 2
MSI (s) (10:E8) [10:15:31:258]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (s) (10:E8) [10:15:31:258]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\DevDiv\Windows\Servicing\14.0\toolscore 3: 2
MSI (s) (10:E8) [10:15:31:258]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\WOW6432Node\Microsoft\DevDiv\Windows\Servicing\14.0\toolscore 3: 2
MSI (s) (10:E8) [10:15:31:259]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (s) (10:E8) [10:15:31:259]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Microsoft\DevDiv\vs\Servicing\15.0\devenv 3: 2
MSI (s) (10:E8) [10:15:31:259]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE32\SOFTWARE\Wow6432Node\Microsoft\DevDiv\vs\Servicing\15.0\devenv 3: 2
MSI (s) (10:E8) [10:15:31:260]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (s) (10:E8) [10:15:31:260]: PROPERTY CHANGE: Adding WIN10TLS_PREVIEW property. Its value is '15.0.26208'.
MSI (s) (10:E8) [10:15:31:261]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (s) (10:E8) [10:15:31:261]: PROPERTY CHANGE: Adding WIN10TLS_PREVIEW_WOW property. Its value is '15.0.26208'.
MSI (s) (10:E8) [10:15:31:261]: Doing action: LaunchConditions
Action ended 10:15:31: AppSearch. Return value 1.
Action start 10:15:31: LaunchConditions.
MSI (s) (10:E8) [10:15:31:262]: Doing action: ValidateVisualStudioVersionCustomAction
Action ended 10:15:31: LaunchConditions. Return value 1.
MSI (s) (10:88) [10:15:31:264]: Invoking remote custom action. DLL: C:\Windows\Installer\MSI6A70.tmp, Entrypoint: ValidateVisualStudioVersion
MSI (s) (10:80) [10:15:31:264]: Generating random cookie.
MSI (s) (10:80) [10:15:31:265]: Created Custom Action Server with PID 2200 (0x898).
MSI (s) (10:90) [10:15:31:287]: Running as a service.
MSI (s) (10:90) [10:15:31:288]: Hello, I'm your 32bit Impersonated custom action server.
Action start 10:15:31: ValidateVisualStudioVersionCustomAction.
ValidateVisualStudioVersion: Initialized.
ValidateVisualStudioVersion: Loaded a property value. Name: TARGETVISUALSTUDIOVERSION, value: 14.0.24720.
ValidateVisualStudioVersion: Acquired target VS version string: 14.0.24720.
ValidateVisualStudioVersion: Loaded a property value. Name: TARGETWINDOWSSDKVERSION, value: 14.0.24720.
ValidateVisualStudioVersion: Acquired target Windows SDK version string: 14.0.24720.
ValidateVisualStudioVersion: Could not loaded a property value. Name: VS14UPD1
ValidateVisualStudioVersion: Could not loaded a property value. Name: WIN10TLS1_2
ValidateVisualStudioVersion: Could not loaded a property value. Name: VS15
ValidateVisualStudioVersion: Loaded a property value. Name: WIN10TLS_PREVIEW, value: 15.0.26208.
ValidateVisualStudioVersion: Acquired installed Windows SDK preview version string: 15.0.26208.
ValidateVisualStudioVersion: Could not loaded a property value. Name: VS14UPD1_WOW
ValidateVisualStudioVersion: Could not loaded a property value. Name: WIN10TLS1_2_WOW
ValidateVisualStudioVersion: Could not loaded a property value. Name: VS15_WOW
ValidateVisualStudioVersion: Loaded a property value. Name: WIN10TLS_PREVIEW_WOW, value: 15.0.26208.
ValidateVisualStudioVersion: Acquired installed Windows SDK preview version string from Wow6432Node: 15.0.26208.
ValidateVisualStudioVersion: Error 0x80070057: Failed to acquire a detected Visual Studio version property string in custom action.
MSI (s) (10!24) [10:15:31:311]: Product: HDE 10.0.14393.0 -- Error 1608. This product requires Microsoft Visual Studio 2015 with Update 1 and UWP tools version 1.2.
@riazmuns did you ever figure this out? I have the same issue.
