Adding external DLL
MaxThom
Hi all, so i've been developing for hololens since mid January. We have an IdentityServer using OpenID. For hololens, I implemented the DeviceCode flow by adding IdentityModel.dll and
System.Text.Encodings.Web.dll. Everything work fine in the editor, but I cant build project. Each time i try to build i get error :
If you have any hint, thank you !
UnityException: Failed to run serialization weaver with command "-pdb" "-verbose" "-unity-engine=Temp\StagingArea\Data\Managed\UnityEngine.CoreModule.dll" "Temp\StagingArea\TempSerializationWeaver" "-lock=UWP\project.lock.json" "@C:\Users\MAXIME~1\AppData\Local\Temp\tmp5a08c988.tmp" "-additionalAssemblyPath=Temp\StagingArea\Data\Managed".
Do these dll's support the UWP platform? Are you building with IL2CPP? (would try that if you are not)
At the time, I was building with .Net. Chaging to IL2CPP made it work, but I had new problem that I explained here
https://stackoverflow.com/questions/54758697/dll-conflict-in-hololens-with-il2cpp-backend
