Convert PST to MBOX and Import Outlook to thunderbird
Try this Regain PST to MBOX Converter tool and convert your PST file into MBOX file in just easy process. This tool can store the MBOX file after performing conversion at any desired location in this system. It is the best option for you as it is very user friendly and flexible. This tool Instantly Convert PST file to MBOX format. this tool Support 20+ Email Clients and also Converts Encrypted PST files into MBOX file.
Includes Advance Data Filter option:-
After clicking MBOX as an option to save file, the tool displays another window with various features. Another option is “Apply Data Filter” Apply the date range and you can conduct selective conversion of Outlook into MBOX.
You can download this software free demo version from here: http://www.psttomboxconverter.emltopstutility.com/
  • edited January 2019
    Thank you
  • There are Multiple tool available on the internet for converting PST file to MBOX file but if you don't know which tool perfect for you then I want to Suggest you PST to MBOX Converter Software because when I had same problem with my Outlook PST file then my friend suggest me this tool when I Used this Software then I had got best results. So I suggesting you this Software this Software easily convert your PST file into MBOX file in just one go. https://www.datavare.com/software/pst-to-mbox-converter-expert.html
  • Use MailsDaddy PST to MBOX converter for the best result. This is an advanced solution to migrate single or multiple PST file to MBOX format in few simple clicks. After converting PST to MBOX you can easily import MBOX data into Thunderbird mailbox.
  • Thanks for the recommendation. I want to recommend another software that I used to convert my Outlook PST files to MBOX. The tool is PST to MBOX Converter and is very easy to use, supports batch conversion and maintains data integrity throughout the conversion procedure. For more information, you may visit:- https://gallery.technet.microsoft.com/PST-to-MBOX-Converter-Bulk-67497763
  • Give a try to another helpful PST to MBOX Software to transfer your PST mail without harming original mail attributes. It's quick to fix answer to move PST file and convert PST to MBOX with all details. You can use this tool to keep care security of original email ingredients and its original part. Visit here: https://www.sametools.com/convert/pst/
  • edited February 2019
    However, performing PST to MBOX conversion is not an easy task, when you want to migrate several PST files or an entire PST account into MBOX in Mac OS. Instead, you should use a trustworthy Mailvita PST to MBOX converter for mac application to perform bulk PST to MBOX conversion safely. It consists of several advance features which makes an easier task for users to change their PST files into MBOX format. It is easy to use application. The software is easy to use and Change PST MBOX in very less time. Because of its easy user interface the software is much preferred among users and its time saving part is also favorite among users.
  • I want to add one more software developed by Coolutils. The software is called as Total Thunderbird Converter This will not only imports MBOX files but also maintain file structures. You can add images into output of emails also converts attachments as messages too. You can check the software here - https://www.coolutils.com/TotalThunderbirdConverter
  • Check out the solution which makes PST to MBOX conversion process easy. It supports many conversion for PST file.
    Check: http://www.axblaze.com/products/psttombox-converter.html
  • I would like to tell you about a blog where I have found manual tricks and as we know manual tricks are not trustable for that an expert solution is also mentioned know it is up to you either to be smart and choose the best tool or waste your time in searching for the best tool.
    Click to know more
  • Mac PST to MBOX Converter is a powerful application for all users. This Software can convert Outlook PST data to Apple Mail MBOX data. This software easy to fit a budget and get it to convert your Outlook PST data to Apple Mail MBOX data. The software capable password protected PST file can also convert to MBOX format just one click. It supports all versions of MS Outlook and Mac OS.
    For more information: https://www.toolscrunch.com/mac-pst-to-mbox-converter.html
  • If you want to convert your PST file to MBOX file format, then you can download ToolsGround Outlook to MBOX Converter software. This is a very good solution provided for converting PST. This software is very easy to use and secure to transfer your data.
    More Info:- https://www.toolsground.com/outlook-converter/mbox/
