SysOZ OST to PST Converter
edited March 2019 in Discussion
OST to PST Converter Software is very powerful and graceful application to resolve Outlook OST file complicated issues and gives the incredible features to save the converted OST emails items: emails, contacts, meeting, deleted items, sent items, calendar, attachment, junk mail, images, header, body content, notes, draft, task, and outbox into PST, MSG, Office 365, MBOX, Live Exchange Server, EMLX, vCal, EML and vCard formats. With the help of this OST file converter software is well supported all Microsoft Outlook versions office 2019, Office 2016, Office 2013, Office 2010 and Office 2007 etc.
    For an instant result of OST to PST conversion, Kernel for OST to PST Converter software is best and secure option. By using this utility, you can fix OST errors and move them into accessible PST formats. It also supports to recover deleted or inaccessible Outlook mailbox items from OST files. To know more about the software, visit: https://www.nucleustechnologies.com/blog/free-methods-convert-ost-to-pst-file/
    Microsoft OST to PST converter by **KDETools **is a very famous tool that easily converts OST file into PST file without creating any issues. It can allow to multiple emails conversion options: - PST, MSG, EMLX, MBOX, EML, HTML etc. It can successfully convert OST emails properties for example - calendar, contact, task, inbox items; outbox items, draft journal etc. It works very fast and provides 100% best results in the conversion of OST file into PST Outlook data. It supports all MS Outlook & Window version.
    Install anytime to third-party OST a PST Converter that perfectly change unreachable OST file and its related mailbox items such as attachments, appointments, drafts, lists, links, notes, calendars, contacts, emails, journals, deleted items, sent items and email properties (Date, time, To, CC, BCC, From and Subject).
    After the move of OST files, the tool quickly converts them to accessible Outlook PST and many other file formats such as MSG, EML, EMLX, MBOX, and VCF as per the individual's predilections. It works perfectly on any versions of Outlook and Windows including Win10 without having any mismatch difficulties.
    For more info, click: https://www.sametools.com/convert/ost/
    gwengwen
    edited April 2019
    OST to PST Converter which sleekly reforms required OST files along with all emails, their components, and attachments. The tool enables you to save all contacts separately to VCF format. I hope this tool proved a fully usable solution for you.
    For more info: http://www.osttopst.filefixutility.com/
    Get a reliable and safe solution to convert OST to PST, EML, and MSG format by using Shoviv OST to PST Converter software. It also provides a quick solution to repair corrupted OST files and export OST to Office 365 and Live Exchange server. Users can also download a free trial version tool.
    OST4 OST to PST Converter application mainly designed for the conversion work from offline OST file to Outlook PST file format. The application does not consume more time in the conversion work. You can save your data into many file formats like PST, EMLX, vCard, MBOX MSG, and vCal. Apart from its support cloud-based application Office365 & Live Exchange Server. It gives you an accurate result that is better than your expectations.
    Use this Regain OST to PST Converter and convert your single and multiple OST file to PST file in just few clicks.
    Try free demo here:
    https://download.cnet.com/Regain-OST-to-PST/3000-2367_4-77435711.html
    DotStella Outlook Forensics Wizard software is one of the best solutions for importing / exporting OST files to PST format with a few easy clicks. Directly convert OST data items to PST mailbox. The software also provides a free trial to test the functionality of the tool.
