Best Converter tool for OST to PST Migration
There are no any such tools for freely converting OST to PST file online. But If you want to convert your OST file into PST file then you can also try this Amazing Software free trial version In free trial version of this Software you can easily Convert your OST file to PST file in just few clicks. free trial version allows user to save 30 emails per folder at free of cost. you can also see the preview of all Convertible emails in free trial version. If you get good results by using this software free trial version then you can easily buy this software full licence version.
Download this Software free trial version from here:
http://www.convertosttopstutility.com
    A number of OST to PST Converter tools are available on the web. But it is not easy to say which one is the best tool. However, you can try a free trial version of Shoviv for OST to PST Converter tool to know its features and working ability. Using this tool, users can also export OST to PST, EML, Office 365 and Live Exchange server.
    Read this blog: https://shovivtools.wordpress.com/convert-ost-to-pst/
    If you are looking a utility a tool which moves your OST file to Outlook PST. Then here is the best app, OST to PST Conversion Tool where you can shift OST file to Outlook. This exporter performs converter of each aspect of Outlook files, such as emails, calendar items, contacts, journal etc. with attachments.
    You can install this tool free demo version from here: https://www.sametools.com/convert/ost/
    If you don't have much time or expertise to repair and recover email data from damaged OST file. Then you can try OST to PST Converter to recover OST files and save them to PST format.
    For more details: http://www.osttopst.adwages.com/
    There is no need to purchase any third party tool if you have exchange server connectivity. In case, if it is no longer available then you have to use third party tool for OST to PST conversion.
    edited March 2019
    If you guys are looking for the best tool for OST to PST migration then do not forget to use Microsoft OST to PST converter by KDETools. With the help of this software, you can easily migrate OST to PST in just a few clicks. All you need to do is open OST file and choose Save to PST. This tool is fully capable to recover corrupted OST file and deleted items and convert into PST file easily. It has features to save converted ost file to PST, EML, MSG, MBOX, HTML etc file formats. You can select any file format to save converted ost file. This tool smoothly exports all emails to other file formats.
    Just google out you will find the best OST to PST converter, check out their reviews and features to pick the best one. Personally, I would suggest you to go for Aryson and SysInfotools OST to PST Converter. Checkout this blog https://bit.ly/2CHg1oM
