MBOX to PST Converter Software
For the conversion task of MBOX to PST, users can download ATS MBOX to PST Converter application that is made up with the rich algorithm and the best technology. Using it users easily export their data into several interesting file formats like PST, EML, MBOX, HTML, vCal, vCard, MSG and EMLX. Before the actual conversion, it displays the preview of recovered mailbox along with email, draft, task, attachment, notes, contact and Metadata like To, Cc, From, Bcc, Date and Time. This application is known for its great work that makes it advanced and user-friendly. It supports Office365 & live Exchange Server that is a very important part of this conversion tool.
Read More Info: https://www.bulkecommerce.com/store/ats-mbox-to-pst-converter-171.html
  • The user can this MBOX to PST Converter for Mac if they are using any version Mac OS and easily convert the MBOX files which support in many email clients into Outlook PST format. The application is very simple to operate and the user which don't have technical knowledge can also use it.
    For more info visit:- https://www.toolscrunch.com/mac-mbox-to-pst-converter.html
  • MBOX to PST Converter is a safe and secure utility software which can effectively convert MBOX file of different mail client to Outlook PST format. The software also supports any type of corrupted MBOX file and restore the recovered data into PST, MSG, EML, RTF and HTML formThis.
    Visit at ; https://www.dailysoft.org/mbox-to-pst.html
  • hanahhanah
    The manual process to migrate Google Gmail MBOX files to PST is not very simple. There are a number of third-party solutions available for the same. MBOX file can be extracted from Gmail through Google Takeout Archive. PST file format is supported by Outlook and other platforms also.
    The easy and quick conversion can be done using Google MBOX converter tool. It has a number of vibrant features.
    1. The tool supports all Windows versions.
    2. Batch migration is possible using this software.
    3. The user interface is quite simple and eye-catchy.
    4. The tool exports MBOX to different versions of MS Outlook.
    5. Selective files can also be migrated.
    There is a trial version available for the utility if you want to experience using the tool once before purchasing.
  • To convert MBOX to PST file, you can also try Kernel for MBOX to PST Converter software. The software can export MBOX/MBX/MBS to PST or Office 365 without facing any issues. For more information about the software, visit: https://www.nucleustechnologies.com/blog/free-methods-to-convert-mbox-to-pst-file/
  • demetriodemetrio
    If you are finding any 3rd party software to convert MBOX to PST you could easily do with Total Mail Converter tool introduced by Coolutils. Apart from conversion you can convert attachments to DOC and PDF. Easily export field like - SENDER, RECIEVER, DATE etc. You can read more about it - https://www.coolutils.com/TotalMailConverter
  • If you want to convert your MBOX files to PST format, MBOX to PST converter from Bitdataconversion can surely help you. It is an efficient solution to export MBOX to PST with ease. The easy to understand user interface of the software helps a non-technical user also to do the conversion without any external help.
    Moreover, its advantages make it more useful:
    • The tool lets the user do selective migration
    • All Windows versions are supported by the software
    • For MBOX to PST conversions, there is a special feature to export MBOX to Office 365 and Live- Exchange
    • The utility does conversions to various Outlook versions also
    • Preserving the folder hierarchy as well
    • Selective MBOX file conversion
    For more info visit here: https://techbizy.com/eml-converter-is-the-best-solution-to-convert-eml-to-pst/
  • perkerpeterperkerpeter
    edited March 28
    If you are looking for a solution which can help you to import MBOX files into Outlook PST then I want to suggest you use KDETools MBOX to PST Conversion tool. This software is the easiest tool to migrate all mailbox data cratered by email clients including Apple Mail, Thunderbird, Entourage, Postbox, Eudora, PocoMail, Netscape, Opera, Spicebird, PowerMail, Claws Mail, Evolution, SeaMonkey, Sylpheed, and others. This Mbox to Outlook PST software can convert multiple file formats such as Mbox to PST, EML, EMLX, MSG, etc. it supports all MS Outlook versions.
    you can download from here:-https://www.kdetools.com/mbox-to-pst-converter.html
  • chriswarnerchriswarner
    edited July 9
    Are you looking for Mbox Converter, I suggest one of the best Software at present in the market.This tool can converts Mbox files into Multiple Formats like MSG ,HTML,EML,EMLX, PST ,PDF etc. The software has no limitation of size, large size also converted into PST. The Mbox file supported by Apple Mail, Thunderbird, Opera Mail, to PST files for Outlook. this tool can support all versions of ms outlook such as 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019.
    Click Here : http://www.mboxmails.com/
  • Jenny_SamuelJenny_Samuel
    edited July 16
    I have a good news for you, recently I have used a solution on my Apple Mail MBOX data and this job is working very well. So I want to recommend you to it, the name of the software is MailsDaddy MBOX to PST Converter. Including Apple mailbox, it supports other MBOX based email client such as Entourage, Netscape, Opera, SeaMonkey, etc. The tool has a number of useful points that help you migrate MBOX data without any hassle to Outlook. And of course, you can use this solution on window versions and can do the conversion process for Outlook 2019, 2016, 2013 etc.
  • Transfer MBOX files to Outlook PST file format with the help of SysBud MBOX to PST Converter. With the help of this, you can easily convert the unlimited number of MBOX files and allows saving them in PST format. This single wizard application provides an easy user interface, so you can use it, without any technical knowledge. In this MBOX to PST converter tool swiftly export large size MBOX files to PST. The utility support 25+ MBOX based email clients such as Thunderbird, Mac Mail, Sea Monkey, Opera mail, etc.
  • Last day, I found software to transfer MBOX to Outlook PST file format. I want to share with Loren and some other persons who are worrying with a similar problem; they can try MBOX to PST Migration Software. Without any difficulty, this tool will work on any Windows like 2003, 2016, 2019 or others. Know more details: https://www.sametools.com/convert/mbox/
  • It was really difficult to find an MBOX to PST converter software that lived up to my expectations. After going through like ten of them, finally, I was able to decide on SysTools MBOX to PST converter. I was able to use it and convert all my 8 MBOX files into PST format. This tool is compatible with MS Outlook 2019, 2016, 2013 and works on all Windows versions (I used it on Windows 10). I had no issues during the conversion process and all the MBOX emails had their header and attribute perfectly intact. For more information, please visit:
    https://www.systoolsgroup.com/mbox-to-outlook-converter.html
    Hopefully, it will help you the same way as it did for me.
  • shinamilershinamiler
    edited September 18
    Here is a perfect solution to import your Maildir files in different formats. The software has utility to execute conversion of Maildir folder or sub-folders to many file formats like Outlook PST, MBOX, PDF, HTML EML, and MSG. It allows the users to perform quick, accurate and complete migration of Maildir emails & backup Maildir (Postfix, Dovecot, Mutt, Kmail & other Linux based email clients) into other various formats.
    And I would suggest you to go with the demo version of the software. So, that you can get an idea about the tool. For more information have a look:
    articleted.com/article/80910/14551/-Convert-Maildir-To-PST
  • If you are looking for a solution MBOX to PST Converter. then try ZOOK MBOX to PST Converter enables user to convert multiple MBOX files to PST format. It instantly migrates MBOX to PST format to extract mailbox data and their data items into Outlook PST format.The advance tool can easily supports all the MBOX file of multiple email clients like Mozilla Thunderbird, Mac Mail, Eudora, Entourage, Spice Bird, Opera Mail and many more.
    It provides two different options to convert MBOX to PST format by which they can convert single MBOX file as well as multiple MBOX files in a single process. In the demo edition of the utility, users can convert 25 items from MBOX files into PST format.
    Explore more:- https://www.zooksoftware.com/mbox-to-pst/
  • To make the MBOX to PST conversion process simple and reliable, you should use any proficient third party tool. You can do this manually, but If you are not a technical expert, then it is very difficult for you to get satisfactory results. When I had faced this problem, I had used Bitacube MBOX to PST converter. The tool has a simple GUI, that easily exports MBOX to PST without any hassle. With this solution, the user can easily perform bulk data migration. Another best thing is that it never loses a bit of data during the conversion and preserves the folder structure, attachments & mail-properties.
    Read More: https://bitacube.com/mbox-to-pst-converter.html
