Best Outlook OST to PST conversion tool by Dux
Dux gives you Best Outlook OST to PST conversion tool to convert your MS outlook file into PST format.
Read more - https://www.duxdatarecovery.com/ost-to-pst-recovery.php
    To get the best solution to convert OST to PST format, I would suggest users download a free trial version of Shoviv Outlook OST to PST Converter software. This tool also helps users to export OST to Office 365, Live Exchange server, EML, and MSG.
    edited March 2019
    Microsoft OST to PST converter by KDETools is the best conversion tool for OST to PST. It allows the OST file conversion into PST, MSG, EMLX, MBOX, EML, HTML etc with all email elements. It can successfully convert OST emails properties including calendar, contact, task, inbox items; outbox items, draft journal etc. It supports all MS Outlook & Window version. You can download the free demo version to convert 30 emails from each folder for free.
    Have a look here: https://www.nucleustechnologies.com/blog/free-methods-convert-ost-to-pst-file/
    This is an article about OST to PST conversion methods, which can help you to convert OST to PST without any issues.
    I hope you all get some of the tools on the internet by searching for your queries. I have also found the best tool for you in the form of OST to PST Converter. The tool simply repairs complete OST file data without any loss.
    Before the actual conversion work, OST4 OST to PST Converter application show recovered mailbox preview then store the overall data into newly created Outlook PST file format. It has multiple saving formats that collect the final data after completing the conversion work. The file formats are PST, EML, EMLX, MSG, vCal, vCard, and MBOX. Apart from it support Office365 & Live Exchange Server.
    To export OST to PST for Outlook, you will require to use this answer it works easily. Beforehand I had tried it also to transfer OST emails to Outlook. I attained complete migrator outcome within several minutes. You can also use it with its free trial capability, in which you can convert 10 emails from each OST files to PST from Outlook Mail in Windows without any cost. Get complete information here: https://www.sametools.com/convert/ost/
    Here you can find the best Solution for SysOZ Outlook OST to PST Converter Software that can easily repair and recover damaged Outlook OST file as well as allow you to export emails in MS Outlook PST file format.
    Microsoft OST to PST Converter Software also provides you with the option to search and save individual email messages from within OST files. ATS OST to PST conversion utility is the best way to get back your data tool which can easily change OST data with overall exist data safely and repairs all mails items, folder, and offline file and saves them to new Outlook PST files. In case you do not have the time to convert all OST items into PST, you can choose specific email messages to be recovered from the OST data based with several properties such as 'To', 'From', 'Subject', and 'Date' and convert them into a variety of formats including MSG, EML, EMLX, vCal, vCard, MBOX, HTML, and MBOX formats.
    Read More Info: ATS OST to PST Converter Software
