Low Latency MRC
hi,i want live preview of hololens on PC.there are two methods: wifi and USB.i use the microsoft Hololens app on windows store and web browser,i find the latency can't accepted,wifi with microsoft Hololens app almost have 1-2 seconds latency,web browser almost have 3-4 seconds latency.i also have try the example of https://github.com/Microsoft/MixedRealityCompanionKit, the HoloLensCommander example is builded successfully,but the latency almost have 2-3 seconds.the LowLatencyMRC example don't build successfully,can anyone know other way to reduce the latency.thank you.
i have fixed the problem,only make sure enable the Windows10 SDK of VS2015
@junqiangchen Did you fixed the problem with the MixedRealityCompanionKit or which method is the best?
