How to Convert PST file to Office 365 Platform and Other format
If You don't know which Converter perfect for you for Converting PST file to Other file format then Use this Regain Outlook PST Converter Software and Easily Convert Your Outlook PST file into MBOX, EML, MSG, EMLX, vCal, vCard and Office 365 Platform. This Software has GUI Interface where you can easily Operate this Software. No technical knowledge Required to Operate this Software.
CheckOut this tool free demo version from here:
http://www.outlookpstconverter.emltopstutility.com/
  • Jamie_9Jamie_9
    edited March 2019
    KDETools PST to Office 365 is the best tool to Import multiple Outlook.pst files to Office 365 mailbox Quick & complete migration of PST items like emails, contacts, calendars, notes, tasks, journals, etc. Convert data from all folders like Inbox, Outbox, Sent Items, Drafts. For more information, you can visit our site: https://www.kdetools.com/pst-to-office-365-migration.html
  • If you are searching the manual process then you can use the Network Upload Method which is provided by Microsoft. But if you are searching the third-party software for converting PST to Office 365, then I recommend you to use PST to Office 365 Migration Tool. In this application, you do not need any Command. For more details, you can visit: https://www.osttopstapp.com/pst-to-office-365.html
  • You can use the in-built method provided by Microsoft, which is the network upload method to import PST to Exchange Online. Apart from this, you can go for the second method which is using the software. This is the simple method which you can try to convert the PST data file to Office 365. The software named as MailsDaddy PST to Office 365 Migration Tool is a perfect solution for this. This software is designed with better features as per the needs of the current organization. The tool allows instant migration of PST data file to o365 accounts. Provides the preview of data along with all its attachments. Here, you do not require the use of PowerShell. The software can be handled by anyone because it is GUI-based. Its advanced search option helps in looking out the file very easily even if you do not know the location.
    Download link: http://www.psttooffice365.com/
  • Checkout Bitacube PST to Office 365 migration tool which I recently used in my environment. It has powerful algorithm to migrate from PST to Office 365 in hassle free manner. http://www.bitacube.com/outlook-pst-repair.html
