Recover unsaved Excel file
Have you lost your Excel file because you accidentally closed it without saving? Or the system crashed unexpectedly? This is really frustrating as you may need to start from stretch!
But Relax!!! as there are few ways that help you to recover unsaved Excel files.
Well, you may not get the latest version but it is worth and that starting from scratch. So take a look at the recovery methods and restore unsaved excel workbook
There are three ways to recover unsaved or overwritten Excel data
Read the article to follow the complete steps: http://www.repairmsexcel.com/blog/restore-unsaved-excel-file
  • Below mentioned steps will lead you to recover the unsaved excel files:
    1. Visit the file tab and click on ‘Open’ button.
    2. Now select the Recent Workbooks option on the top left corner of the screen.
    3. Now scroll to the bottom screen and choose the ‘Recover Unsaved Workbooks’ option.
    4. Go through the list and search for the file you have lost.
    5. Thereafter Double-click on the file to open it.
    6. The document will be visible to you in Excel. Now hit the save as button to save the file.
  • Hi,
    It can happen that you have lost your unsaved Excel files due to corruption or other excel application reasons. There are manual methods that you can use to recover unsaved Excel sheets. One such method is:
    Method #1.Recover unsaved Excel 2016 with AutoRecovery
    1. Start by Opening a new Excel document in Windows PC.
    2. Click File > Tab Recent, check recent used Excel documents and find the exact one – unsaved Excel document.
    3. Click Recover Unsaved Excel Workbooks and then wait till the Excel workbook is recovered.
    4. The Open dialog box will pop up, after which open the exact lost Excel document and click Save As to save the document into a safe spot on PC.
    You can also refer to the post: Recover unsaved files in Excel
  • edited August 2019
    In addition to the autosave and recently saved methods mentioned above, there are other ways to recover the unsaved Excel file, such as restore and restore older versions from temporary folders. This is the procedure for restoring the old version:
    1. "File" Options > "Information" > Find "Management Version", you can see all the automatically saved versions of Excel documents, and each version is date and time.
    2. Select the Excel file you need to restore and click the "Restore" button to resume.
  • AmiliiAmilii
    edited September 2019
    There are several ways to recover unsaved or corrupted excel files,
    1. Go to the file tab and click on ‘Open’
    2. Now click on the Recent Workbooks option on the top left
    3. Now scroll to the bottom and click on ‘Recover Unsaved Workbooks’ button
    4. Scroll through the list and search for the file you lost.
    5. Double-click on it to open it
    6. The document will open in Excel, now all you have to do is hit the Save As button
