MBOX to PST Converter Software
For an easy and instant solution to Convert MBOX file to PST files, then you should try to take help of any perfect Conversion Application like Regain MBOX to PST Converter Software that can easily transfer or move MBOX files of different mail client to Outlook PST files. This Software Instantly Convert MBOX file to PST File in just few Clicks. This Software also Shows the Preview of all Convertible emails before Saving.
Download this Software free demo version from here: http://www.mboxtopstconverter.emltopstutility.com/
    To export MBOX files to Outlook PST there is manual as well as expert answer. Both answers have their own benefits. But if you want to migrate MBOX to PST easily without making any extra work for yourself try to convert MBOX files with some application like MBOX to PST Converter. If you want to export MBOX to PST manually you can check this out: https://www.sametools.com/convert/mbox/
    edited April 2019
    Download latest Softaken MBOX to PST Converter for the conversion of unlimited MBOX files to Outlook PST format.
    demetriodemetrio
    edited May 2019
    If you will google it, you will find many websites through which you can convert MBOX to PST. But I will suggest you to try CoolUtils Total Mail Converter. This tool has user-friendly interface and easy to use for everyone. It's just a matter of seconds you will get your processed PST files from MBOX. You can read about it from here - https://www.coolutils.com/TotalMailConverter
    KDETools MBOX to PST converter is a reliable and risk-free converter which can quickly convert MBOX files into PST format and support 20 other email clients which support MBOX files format such as Seamonkey, Eudora, Thunderbird, Spicebird, etc. The tool also allows users to export MBOX files into Live Exchange server, Office 365. You must try a trial version which offers to convert the first 25 items/folder as well.
    If you want to convert MBOX files into PST format then, I would like to suggest try Shoviv MBOX converter tool that allows to convert multiple MBOX files into PST format and also export MBOX files into Office 365 and live Exchange server. Get this brilliant tool which also comes with a trial version and available at the affordable price range.
    edited June 2019
    I want to suggest a swift solution, which takes a few simple steps to import the MBOX to PST format. The name of the tool is SysBud MBOX to PST converter that is built on a single wizard. It is able to preserve folder structure, rich text formatting, inline images and attachments. The tool supports all window versions and provides adaptable PST file for Outlook 2019, 2016, 2013 and other older versions.
    If you want to Transfer your MBOX file to PST file but you don't know how to Convert MBOX files to PST files So you need to download WholeClear MBOX to PST Converter tool. Try this Software free demo version and see the original results and this tool support all Windows version.
    Visit here: https://www.wholeclear.com/mbox/pst/
    MBOX to PST Converter for Mac both are different file formats for storing mailbox data. Neither MBOX to Outlook provides any utility for converting MBOX to PST format. But there is a manual trick that can easily export entire MBOX emails to MS Outlook PST. Through the manual trick you can export Lotus Notes emails to either Comma Separated value or Structured Text format. After exporting MBOX file data into these formats to MS Outlook format.
    For more info visit here:- https://www.mailvita.com/mbox-to-pst-converter-for-mac/
    Now i got another best application that name is MailsDaddy MBOX to PST Converter. User can use this tool on multiple email client and convert MBOX to Outlook PST, Office 365, Live Exchange, HTML, MHTML, EML, MSG etc.
    To know more about tool visit Official site.
    johnharryjohnharry
    edited December 2019
    How to convert MBOX to PST and how to migrate MBOX to Office 365, which are the basic questions users have in mind. There are many tools available on the web, but how to choose the best tool. I can suggest here best tool such as Bitacube MBOX to PST Converter. I suggested this tool here because of my personal experience with this tool is superb. This tool provided me a complete solution to convert the MBOX file to PST format without any time consumption and complicated method. You can chek here this tool free trial version: https://bitacube.com/mbox-to-pst-converter.html
    GemmaWardGemmaWard
    edited January 2020
    If you have any issue related to MBOX to PST Converter. MBOX converter helps to Import the data in discrete file formats such as EML, EMLX, HTML, MSG. MBOX supports multiple email clients like including Apple Mail, Pocomail. Eudora, Spicebird, Entourage, Google takeout, Netscape, SeaMonkey, and many more. MBOX converter is suitable for the Office 365 server and Live Exchange.
    More information: https://gust.com/programs/how-to-move-mbox-to-pst-file-format
