Best technic to Convert MBOX to PST ?
in General
please tell me how to convert MBOXfile into PST file format. please help me.
If you want to convert MBOX to PST file, then you can make use of third party MBOX to PST Converter tool to successfully migrate your MBOX file to PST format. The tool is also perfectly works on all versions of MS Outlook and Windows platform.
Visit at ; http://www.outlookconverter.net/mbox-to-pst/
MBOX to PST - An easy solution for both professional and non-professional users to convert MBOX files to Outlook PST files for any MS Outlook (2016, 2013, 2010, 2007 and 2003) edition. It can simply run on any latest and Windows OS systems i.e. Win Vista, XP, 7, 8, 8.1 and 10 to convert MBOX files to Outlook PST files without any problem. The software allows two conversion mode - Single mode and Batch mode to convert MBOX files to Outlook PST files without wasting a lot of time. http://www.toolsbaer.com/mbox-to-pst-conversion/
Shoviv MBOX to PST converter is the most reliable and trusted tool which can easily convert MBOX to outlook PST along with many other clients. The tool is able to export MBOX to Outlook PST, office 365, exchange server. Following are some highlighted features of the tool:
Support MBOX more than 20 email client like Eudora, Spicebird, Entourage,
Thunderbird, Seamonkey etc.
Migration of MBOX to office 365 with 100% accuracy.
To migrate emails from MBOX to PST. Follow the following steps:
Click on File >> Open & Export >> Import/Export.
Now, in the Import/Export wizard, select Export to a file and click Next.
Choose Outlook Data File (.pst). Click Next.
Select the folder where EML files are saved and click Next.
Provide the location for the new PST file, choose the desired option, and click Finish to end the process.
If you want to convert MBOX file to PST. Then you can make use of third-party MBOX to PST Converter tool to successfully migrate your MBOX file to PST format. This MBOX to PST converter software also perfectly works on all versions of MS Outlook and Windows. It can migrate of MBOX to office 365 with 100% accuracy. And convert MBOX to Outlook PST with many email clients.
Download and use easy solution to convert MBOX to PST format. This is the easiest way to convert MBOX to PST format as there is no manual way to do this.
Visit: http://www.axblaze.com/products/mboxtopst-converter.html
I would recommend you to use Total Mail Converter developed by CoolUtils. They are serving their customers since 2007, so you can trust them. With this tool you cannot only convert MBOX to PST but also you can easily convert EML/MSG formats to TXT, TIFF, XLS etc If you have any question contact them on - +1 (855) 418-2323
You can download them from here - https://www.coolutils.com/TotalMailConverter
Mail Extractor Pro is a tool which helps you to convert your MBOX files to PST files with it's special in-built features which allows you to use this tool easily without any complications.
1. Load
2. Setting
3. Convert
You can download it from here: [https://uslsoftware.com/mbox-to-pst-converter-for-mac/])
You can try MBOX to PST Converter for Mac this application quickly export and migrate MBOX file data to Outlook PST file. MBOX to PST Converter for Mac tool can easily maintain email folders to restoring CC, BCC, To, From, and attachments. It also a simple and fast conversion. This software supports all MS Outlook and all Mac OS versions. It is also capable to support multiple MBOX based email clients such as Entourage, Eudora, Apple Mail, Mac Mail, Thunderbird Mail, etc. This software supports all Mac OS versions and MS Outlook versions.
Try dependable utility to Convert MBOX mail to PST. MBOX to PST Converter Tool is professional email migration software that helps to export emails from MBOX to PST, EML, MSG, and EMLX. This utility covers a group of important features to convert MBOX Mail to PST sideways with attachments protection the primary formatting and email qualities safe during the migration procedure.
Try it: https://www.sametools.com/convert/mbox/
