InQuit Lotus Notes NSF file to Outlook PST file- $59
InQuit NSF to PST Converter tool is best that is compatible to convert data from Lotus Notes to Outlook PST file format in a safe manner. The MS Outlook is the requirement of many small and large organizations and it is easy to use. Therefore lots of company prefer Outlook email client to store their official database. Lotus notes very technical to use so the only technical user can operate it.
If you think to use the manual method so I suggest you don’t use it because it does not give assurance to convert full data and there is no guarantee of your database. Use only third-party application Like OST to PST software which is developed by InQuit team.
This Conversion tool has amazing features which help you to overcome the situation of NSF corruption. The GUI of this utility is so simple even a novice user can use it easily without any technical skills. The user extracts their those NSF files easily which is encrypted and password protected. You can easily transfer your data into cloud-based application Office365 & Live Exchange Server.
Features of this program
• This tool does not consume more time during the conversion.
• It support Lotus Notes version such as 9.0.1, 9.0, 8.5, 8.0.2, 7.0, 6.5, 6.0 and, 5.0.
• Show preview of recovered mailbox along with metadata such as To, Cc, From, Date, Time, Subject, Object, and Bcc.
• The user exports their data into several file formats such as PST, EML, EMLX, MBOX, CSV, HTML, vCal, vCard, and MSG.
• It backing MS Exchange Server version 5.0, 5.5, 2000, 2003, 2007, 2010, 2013, and 2016.
Conclusion
If users have any difficulty to operate it for the conversion so they contact us 24x7 hour we are also ready to help. It is can be evaluated easily by downloading its free demo version which gives authority to access 25 email items of each folder.
**Read More Info: ** https://www.inquitsoftware.com/en/nsf-to-pst-converter.html
  • Here I am going to share an NSF to PST Converter software which provides a Free trial version to check out software working ability and features. This tool supports all the version of IBM Notes, Domino server, and MS Outlook.
    Download a free trial version: https://readthedocs.org/projects/shoviv-lotus-notes-to-outlook-converter/
  • Conversion of Lotus Notes to Outlook PST is easy taking the help of ATS NSF to PST Converter application. With the help of this tool you not convert only one file but also convert more than one NSF file into PST along with email, inbox, outbox, contacts, deleted items, drafts, calendars, sent items, notes (to, cc, bcc, subject, date and time). Before the conversion, it shows the preview of recovered mailbox without any difficulty. It is also compatible to extract NSF data into several interesting file formats such as PST, EML, EMLX, vCal, vCard, EML, CSV, MSG, and MBOX. It gives 30 days money back guarantee.
    Read More info:https://download.cnet.com/ATS-Notes-Converter/3000-2369_4-77530262.html
  • If you are searching finest NSF to PST Converter Tool that transfers your complete NSF data to PST format, try NSF to PST software that offers the greatest answer to easily export complete data from NSF file to PST format with all email items and properties. Read more: https://www.sametools.com/convert/nsf/
  • An easy solution to convert NSF to PST is to deploy Export Notes Software which allows you to migrate each item of Lotus Notes like Emails, Contacts, Calendars, Journals etc. It supports all latest versions of Lotus Notes and Outlook too. Multiple NSF files can be easily exported to Outlook PST format. You can try the demo version of tool freely. Know more :- https://www.osttopstapp.com/nsf-to-pst.html
  • The best way to restore Lotus Notes NSF file to Outlook PST file, choose eSoftTools NSF to PST converter Software. This software can convert and recover all the NSF files into Outlook PST, EML, EMLX, HTML, MSG, vCard and many more. It is available for free as it can be tried for free with its demo version. It can even help in PST division also. It is compatible with all versions of Lotus Notes and Windows OS.
    Explore more here: http://www.esofttools.com/nsf-to-pst-converter.html
  • You may effortlessly migrate from Lotus Notes to MS Outlook by way of exporting all NSF document items, including emails, contacts, attachments, calendars, journals, and many others to PST document.
    Try Shoviv Lotus Notes to Outlook converter and migrates the multiple Lotus Notes mailboxes to PST Outlook and save into EML, MSG, and HTML formats. Download its demo version and check all features and migrate the initial 25 items for each folder.
    More details, visit:- Lotus Notes to Outlook converter
  • Try the brilliant NSF to PST Tool to securely convert Lotus Notes NSF mailbox items to Outlook PST format with attachments. It is the well-capable utility to transfer the complete Lotus Notes database to PST including emails, contacts, calendars, briefcase, etc. Opt its batch functionality for converting unlimited NSF data files to PST in single conversion round. Free to download and test the utility on any Windows OS platform.
  • Use NSF to PST Converter tool to migrate from Lotus Notes to Outlook and export complete NSF emails, contacts, calendars, journals, and tasks, etc. in PST format. this software to Restores the converted NSF file into various formats such as RTF, PDF, PST, MSG, EML, and HTML file format. The Lotus Notes to Outlook migration tool is compatible with Windows 10, 8, 8.1, 7, and all previous editions and supported by MS Outlook 2019, 2016, 2013, 2010, and all earlier editions. It preserves all the inline images and attachments of the NSF file and export in PST format same as such. The IBM Notes to Outlook converter tool maintains complete folder structure and data integrity of the Lotus Notes database. Get the process of the tool from http://www.nsf-converter.com/
  • Get the effortless and safe NSF to PST Converter Tool for converting Lotus Notes NSF database to PST file format alongwith emails, contacts, calendars, briefcase, etc. Batch option and preview option is the amazing facility available for users. For getting more about the NSF to PST Converter, you can free to download and perform the conversion process without purchasing it. All Windows editions are compatible with this program.
