Import PST file data into Office 365 with PST to Office 365 Migration tool
Here is an amazing tool that can easily Import PST file data into Office 365, Regain PST to Office 365 Migration Tool is a trusted solution to import Outlook PST files into Office 365 mailbox with ease. if you will use this tool then you will also like this Software. first of all try this tool free demo version and when you get good results then you can buy this Software full licence version.
You can also download this Software free demo version: http://www.psttooffice365migration.emltopstutility.com/
To import PST file to office 365 mailboxes, you can use Kernel Import PST to Office 365 migration software. Try it: https://www.nucleustechnologies.com/how-to/import-pst-to-office-365-without-outlook.html
I would not suggest you any manual method because it seems to be quite complicated. Outlook PST to Office 365 is the quick solution I would say on your problem.
See here:- https://www.softakensoftware.com/outlook-pst-to-office-365.html
Shoviv is also providing a reliable and quick solution to migrate PST to Office 365. Using this solution, users can migrate corrupted and non-corrupted PST files into Office 365, Live Exchange server, new PST, EML, and MSG.
Hope It works
For importing Outlook PST data try MailsDaddy PST to Office 365 Migration Tool. It is a professional software which helps to in converting data very rapidly without any trouble. It exports data either to o365 primary or the archive online mailbox. Uploads the PST data file and provide its preview. Allows us to view the content of each data along with its attachments. Converts PST data to Exchange Online in just a few clicks. Supports PST file of any size either small or large. Import data to users' mailbox with Impersonation right without the requirement of the Password of each user account. The software helps in creating the log file. You can download and run its Demo version to move the top 20 items of each mailbox.
You can simply Move Outlook PST file into Office 365 format. Use this ToolsGround Outlook to Office 365 Migration tool it works very easily and quickly without any trouble. this software migrates your file without any data loss no never compromise your file size you can freely export your file without any trouble.
More info;- https://www.toolsground.com/outlook-to-office-365-migration/
