Do you know how to solve this problem when building under holo? CS0234
I'm new to this and can't figure out how to fix these bugs that keep me from building a project for holo. I would be very happy if you could help me with this problem, I think that it is so easy because I have not found other information about it.
  • @Kent1LG said:
    I believe your problem come from the W10 version used on the build settings.
    Hi, Indeed,I used the old W10sdk. The update helped me fix those bugs and the project can now build. Thanks. But now there are new errors. :)
  • Share me a screen if you want , i can check if i know a way to fix it.
  • Even with all this errors you can build?
    I don't remember where but i saw an issue like your's, on the forum,
    it seems like this is a know bug, already up to the developpers, just
    a little annoying.
  • I can build a project, because these errors appear immediately after construction, but when you start visual studio project otkazyvaetsya work and there are also errors.
