Convert OST to PST file easily
You can Convert your OST file to PST file if you use this Regain OST to PST Converter Software that can easily Convert your OST file to PST file. this Software also Repair your Corrupt OST file and Recover Deleted OST file data like: emails, calendar events, contacts, tasks, notes, drafts etc. Through this Software you can also Convert OST files to PST, EML, MSG, MBOX, HTML, ICS, VCARD formats.
Get this Software free trial version from here: http://www.ostintopstconverter.com
  • Migrate OST data to Outlook PST file with the help of latest OST an Outlook Converter Application. This is an advanced software works resourcefully to move OST file successfully to PST file in contradiction of any obstruction. The OST to PST Software allows users to convert OST file into PST, MBOX, EMLX, VCF, EML and MSG format.
    Read More: https://www.sametools.com/convert/ost/
  • If you are searching for a reliable and quick solution to convert OST to PST easily, then I would suggest you go with OST to PST Converter tool from Shoviv which provides a fast and secure solution to export OST to PST, EML, MSG, Office 365, and Live Exchange server.
    Know More: http://www.ostmailrecovery.com/
  • demetriodemetrio
    edited May 2019
    You can try CoolUtils OST to PST Converter, with this software you can safely recover all your emails, tasks, calendars, contacts etc. Also, it is secure and 100% clean software. It also works even you don't have an Exchange Server connection.
    You can read more about this tool here - https://www.coolutils.com/OSTtoPSTConverter
  • ATS OST to PST Converter is here to remove all the problems in a few minutes without making any changes in the database. While you convert data from OST data file to PST data file it does not lose the data integrity and gives you an accurate result. The software has a preview facility that shows recovered mailbox before the conversion. You can save your resultant file into many file formats like PST, EML, MBOX, MSG, EMLX, HTML, vCal, vCard file formats. A part of this too Office365 and Live Exchange server is always supportable to save PST file for future.
  • To convert single as well as multiple OST files into PST and other file formats like EML, EMLX, MSG, vCal, vCard, and MBOX I would like to suggest OST4 OST to PST Converter application. The application is the perfect way to convert data of OST file into Outlook PST file. At a one time you can convert emails, notes, contact, sent item, delete item, attachment, task, draft, and journals etc. In is free demo version you can convert 30 emails per folder that is absolutely free of cost.
  • OST to PST Software which is the genuine third-party mechanism to allow whole data recovery from corrupt OST file and safely converts them to Outlook PST file format.
    For more info: OST to PST Software
  • InQuit OST to PST converter is a perfect solution which is built by our expert to repair, recover and convert OST to PST. It is the perfect application to maintain all folders or files. You can split your large OST file into small PST file without any file size limitation in few mouse clicks. Using of this software you can easily and safely convert all OST data along with email properties to, cc, bcc, subject, date and time into PST, EML, EMLX, vCal, vCard, MSG, MBOX and HTML in just a few minutes. This application provides a free facility to convert 30 emails in each and every OST folder without the penny.
    Read more: https://inquit-ost-to-pst-converter-toolbox.en.softonic.com
