Do you know how to solve this problem when building under holo? CS0234
D_o_r_G
Kent1LG ✭
Hi D_o_r_G,
I believe your problem come from the W10 version used on the build settings,
Try again with the last version of W10 SDK (also don't forget to change it on the build settings).Tell me if is working,
Quentin LG
Hi D_o_r_G,
Quentin LG
Hi, Indeed,I used the old W10sdk. The update helped me fix those bugs and the project can now build. Thanks. But now there are new errors.
Share me a screen if you want , i can check if i know a way to fix it.
@Kent1LG
Even with all this errors you can build?
I don't remember where but i saw an issue like your's, on the forum,
it seems like this is a know bug, already up to the developpers, just
a little annoying.
I can build a project, because these errors appear immediately after construction, but when you start visual studio project otkazyvaetsya work and there are also errors.
