MBOX to PST Converter Software Converts MBOX files to PST
If you want to Convert your MBOX file to PST file, then I highly recommend Regain MBOX to PST Converter. this Regain MBOX to PST Converter tool is the ultimate solution for converting your MBOX files into Outlook PST file. You can easily transfer your MBOX file into Outlook PST file by Regain MBOX to PST Converter. this Software Converts multiple or Single MBOX files in one go. Use free trial version and save 30 emails per folder at free of cost.
You can try this Software free trial version from here: http://www.mboxtopstconverter.emltopstutility.com/
    edited May 2019
    MBOX to PST Conversion Tool is a simple and active utility which can easily export MBOX file to Outlook PST files and save it in desired location. Convert MBOX to PST will give you the self-determination to view your moved Thunderbird files into Outlook. Export MBOX to PST software has the competence to change large MBOX file to PST file.
    See More Information visit : https://www.sametools.com/convert/mbox/
    I recommend KDETools MBOX to PST Converter. This tool can easily convert MBOX file to PST file. This tool has a very easy interface that everyone can use without having any knowledge of the software. This tool supports other file formats such as MSG, EML, EMLX, PDF, HTML, etc. KDETools MBOX to PST Converter works well for all the latest versions of Microsoft Outlook and Windows. The software does not make any alteration during conversion.
    With the help of a MBOX to PST converter software, you can easily and quickly convert MBOX to PST file. I would also like to suggest such software named as Kernel for MBOX to PST Converter, which can save MBOX mailbox items to Exchange Server, Domino, GroupWise. Try it: https://www.nucleustechnologies.com/blog/free-methods-to-convert-mbox-to-pst-file/
    edited May 2019
    Use Software to Convert MBOX to PST which easily exports MBOX files to Outlook PST format. It easily converts all email properties (to, cc, bcc, subject, from, attachments) and successfully converts MBOX to PST format.
