Import PST file to MBOX file
You can also try one of the best PST to MBOX Conversion solution that will definitely help out to Import PST files to MBOX format without Outlook installation in the system. The software provides option to browse through this system and choose PST file whose emails you want to Import to MBOX. This Software Supports All the Latest version of MS Outlook & other Email clients. Use this Software free trial version and see the Original results.
Get this Software free trial version from here: http://www.psttomboxconverter.emltopstutility.com/
I had also tried it when I desirable to switch PST files into MBOX with Attachments & extra images. I attained the wide-ranging outcome in a few minutes.
For more details, you can check the source: https://www.sametools.com/convert/pst/
PST to MBOX Converter Tool this tool helps to Convert your PST files to MBOX file Format and other emails client like Thunderbird, WLM, Apple Mail, SeaMonkey etc. PST to MBOX Converter Supported MS Outlook 2003,2007,2010, 2013 and 2016. Download Free Demo version PST to MBOX Converter.
For More Information Visit here:- https://www.downloadtopten.com/converter/pst-to-mbox/
