How to Convert Multiple Outlook Contacts to vCard?
edited December 2018 in General
Indya Outlook to vCard Converter is the suitable tool to convert multiple Outlook contacts to vCard file with all the attached information. This application is totally supports all version of MS Windows and Outlook. It is very easy for non-technical users as it comes with simple GUI.
Steps to Convert Outlook PST Contacts to vCard
1. Launch the software and select PST file
2. Select desired folder location to save converted file
3. Click convert button to start PST to vCard conversion
Main Features & Benefits of the Tool
  • 100% guarantee of safe and secure conversion
  • Export Outlook contacts with all details
  • Convert large sized Outlook PST file
  • Bulk export Outlook contacts to vCard
  • Shows live progress report of conversion
Read More: https://www.indyasoftware.com/blog/how-to-export-outlook-contacts-into-vcard/
    PST to VCF Migration Tool is the perfect way out that easily converts unlimited PST files to VCF at once. You can use this software to get the risk-free converter from PST to VCF format. The tool provides multiple advanced features that make the conversion so unique.
    To get more info at- https://www.sametools.com/convert/pst/
    There are many solutions to export import contacts. But depends on the number of contacts.I have a another solution for issue.You can use vCard Export Import to Convert your Multiple Outlook Contacts to vCard.
    To more info :- http://www.completeconverter.com/outlook-vcf-export-import/
    Outlook PST Contacts Export tool is the perfect tool to convert Outlook Contacts to vCard without any problem. The tool comes up with many features. With this software, users can easily save the converted files to the VCF file format. It provides the complete preview of files before the conversion. The tool supports all the MS Outlook and Windows OS editions.
    Hello.
    I'm using KDETools PST to vCard Converter Converts and save Outlook PST data into a healthy PST, MBOX, EML, MSG, EMLX, PDF, and HTML file format. Converts the password protected or encrypted Outlook PST file in the desired format. Exports Outlook PST file including (Inbox, Outbox, Sent box, Draft and Folders Sub-folders), etc. you can Split large PST file into small PSTs (1GB to 25GB). visit for more information on this website https://www.kdetools.com/pst-to-mbox-converter.html
    I understand your situation and that why recommending you Outlook Converter PST to VCF format, last months I used this tool on the advice of my brother.
    You can also try the tool because it provides PST to MBOX, MSG, EML, EMLX, and VCF formats.
    You can visit here:- https://www.toolsground.com/outlook-converter/
    There are many different way to export Outlook contact to VCF format.
    • If you want to export one or two contact in VCF then use Save as method
      Go to file tab.
      Select save as option.
      In the save as type drop-down box, Select vCard files option and save it.
      Now your contact has been exported in vCard or .VCF format.
    • Second method - First export contact in CSV format then convert into VCF format
      In Outlook, open file tab.
      Select “Import and Export” option.
      Choose Export to a file then Next.
      Select “Comma Separated Values(Windows)”.
      Choose Contacts in Export file list
      Browse the location where you want to save CSV file, then click on Next button
      Ensure that checkbox has marked then click on finish button.
    • Now let's convert all CSV file into vCard format
      Click on Start Button
      In search box, type contact
      Now click on import option.
      Browse your .CSV file, where you save it.
      Check the field you want to show then finish
    I hope it will be helpful for you
    I totally understand when it comes to bulk conversion of Outlook contacts to vCard format, no manual solution offer desired results. Thus, in that case, a user is suggested to take help of smart solution like SysTools vCard Export tool. This software will not only let you convert Outlook contacts to vCard but to WAB, Google and Yahoo contacts also.
    There are huge number of solutions that can Export Outlook Contacts to vCard format. Manual as well as automated solutions are there to perform the conversion. But we will provide here an effective and one solution for the conversion i.e. Export Outlook Contacts to VCF Tool. We don’t prefer manual solutions because they are lengthy ones and sometimes unable to perform the required task for you. Moreover, there is no surety of data safety.
    More Info:- Export Outlook Contacts to VCF Tool
    I'm using **DotStella Outlook to vCard Converter **easily export and save Outlook PST data into VCF file format. Converts the password-protected or encrypted Outlook PST file to the desired format. Exports an Outlook PST file including (Inbox, Outbox, Sent Box, Drafts and Folders subfolders), etc. You can split a large PST file into a small personal storage table.
    Step 1: Export Contacts from Outlook
    Launch Outlook. Click File >> Open&Export >> Import/Export >> Export to a file >> Comma Separated Vales (.csv) >> Contacts >> Export
    Step 2: Convert Outlook Contacts CSV to vCard
    Download **SysTools CSV to vCard Converter
    Add CSV file and click Add File(s), select VCF as export option
    Select Mac vCard or Windows vCard and vCard v2.1, v3.0, v4.0. Click Convert
