How to Migrate of Outlook PST File to Other format
I want to Suggest you this Amazing Regain Outlook PST Converter tool where you can Migrate your PST file into Other format like: PST to EML, PST to MSG, PST to MBOX, PST to EMLX, PST to PST, PST to vCal, PST to vCard, PST to Office 365 Platform. Regain PST Converter tool allow user to see the preview of all convertible emails before saving. In preview panel on software interface, you can check all your emails before converting in other format.
**Try this Software free demo here: **
https://download.cnet.com/Regain-Outlook-PST-Converter-Software/3000-2369_4-77945669.html
    Now, you can easily transfer to your PST data into numerous file format like EML, MBOX, and VCF format. But, if you require conversion then you will need use to PST Converter Tool, it is third-party software who quickly move to your data from one file format to another. Get more information here: https://www.sametools.com/convert/pst/
    Here I am going to share one another solution which also helps to export PST file into multiple formats such as Office 365, Live Exchange server, new PST, EML, MSG. Source: http://www.techsite.io/p/784770
    yes i have used PST to MBOX converter tool once when i have to migrate one of my client mailbox data Outlook to Apple Mail in that situation i have to approach a third party tool. I still remember that i have to rush lots of google queries and tools with fake promise but after wasting lots of time i found a utility which suites my requirement and interface are very decent and simple to use i will suggest you to use that tool :- http://www.toolsbaer.com/pst-to-mbox-conversion/
    For migrating Outlook PST file into multiple formats such as Office 365, Live Exchange server, new PST, EML, MSG, HTML, RTF, Cal, and vCard, I would recommend you read this post. https://www.shoviv.com/pst-to-office365.html
    Hope it will help you to accomplish your work
    Looking for a solution how to migrate Outlook PST file to Other format?If yes, then try all-in-one Outlook Export Tool which helps you to migrate Outlook PST files to PDF, MSG, EML, MBOX, NSF, RTF, HTML, DOC, Zimbra, Office365 and etc. with attachments. It allow to convert all emails, contacts, calendars, tasks and etc. There is no file size limitation, you can converts n number of files at a time without any problem. To know more info:- https://cubexsoft.com/blog/how-to-open-outlook-data-file-without-outlook/
    Mac can try this PST to EML Converter for Mac which allows them to export Outlook PST files in EML files format in just a few clicks in Mac OS & Mac OS X. The Mac PST to EML Converter is a sophisticated tool and anyone can use this simple conversion application in there Mac system. Visit here for more details:- https://www.toolscrunch.com/mac-pst-to-eml-converter.html
    The tool which you are looking for saving the PST file into multiple file format is PST Converter tool. This tool provides you multiple options to save the PST file in formats like MSG, EML, DBX, and MBOX. If these are file formats which you are looking for, then for more information you can click here: https://bit.ly/2QqWLEP
    My brother is a professional expert, so he had a great knowledge of migration tools. He suggested me Outlook Converter PST to EML Converter and got instant results. You should also try this tool.
    You can also try the tool because it provides Outlook Converter PST to MBOX, MSG, EML, EMLX, and VCF formats.
    You can visit here:- https://www.toolsground.com/outlook-converter/
