SharedHologram - Upload Failed Room not found
Hi, I am trying to follow the sharedhologram experience(Hologram 240), and I occasionally get an error that says "Upload failed Room not found", after uploading anchor. Sometimes, the application work smoothly, but if this error happens, I can't see any holograms. For the stability, is there any way to fix this issue?
me too.
Help!
Is this error in the editor?
AR Developer
I'm not sure this question still bothering anyone. I recently worked on a project of sharing hologram and I am using unity and holoTool kit 4.3.0. When I meet this problem, I play the app on unity and let the computer to join first and create a room, then when the HoloLens join the session, it will automatically join the room and there will be no Room not found error.
