How can I Convert PST file to Other format like: MBOX, EML, MSG, EMLX, vCal, vCard
If you want to Convert PST file to Other format but you don't know how its possible then I want tell you a Solution where you can easily convert your PST file to Other format. If you try this third party tool Regain Outlook PST Converter where you can easily convert your PST file into MBOX, EML, MSG, EMLX, vCal, vCard and Office 365 Platform. This tool Repair and Recover your Corrupted and deleted PST file.
You can also try this tool free trial version from here:
http://www.outlookpstconverter.emltopstutility.com/
Get one more solution named Shoviv Outlook PST Repair software which also provides multiple features to export PST files. Using this tool, users can export their PST files into EML, MSG, Office 365, new PST and Live Exchange server. It also helps to save PST data into HTML, RTF, Cal, vCal, and vCard format. To know step by step information, you can download a free trial version of this Outlook PST Repair tool.
If you require safe conversion then I will advise you to try PST to MBOX Export to import PST data to MBOX format because it gives you an accurate and mistake-free consequence. The utility has embedded lots of features, which advance its converter piece as well as it effortlessly switches large PST file & folder. With this application, you can save the emails on the spot into given formats and also you can search the email.
To Further info - https://www.sametools.com/convert/pst/
If you want to best solution to convert PST file in other formats then use third party software. I would like to suggest you to best third party software which is KDETools PST to MBOX converter software. By using this software you can convert outlook PST file into multiple file formats like PST to MBOX, MSG, HTML, EMLX, EML, etc. By using this software you can easily Convert Outlook PST to MBOX Thunderbird without any problem.
I would like to suggest Kernel for Outlook PST repair software, which can help you to fix PST errors and recover stored data. It also supports to save PST file in DBX, MBOX, MSG, EML, TXT, RTF, HTML, and MHTML formats. Try it: https://www.nucleustechnologies.com/outlook-pst-repair.html
If you want to convert PST to MBOX is now very easy Process by Using this PST to MBOX Converter Software where you can easily convert your PST file into MBOX file. With the help of PST to MBOX converter, users can smoothly switch from Outlook to MBOX email clients, such as Netscape, Thunderbird, SeaMonkey, and SpiceBird. The tool will offer smooth migration of Outlook data from PST to MBOX. You can then import MBOX in supported email clients. http://www.toolsbaer.com/pst-to-mbox-conversion/
I read your problem, and got that you want to convert your PST files into various formats. So, don't get confused, you can simply use the Outlook Converter. Which is very reliable for your, and you can easily convert your PST files into MBOX, MSG, EML, EMLX, and VCF
Visit here:- https://www.toolsground.com/outlook-converter/
I would like to Suggest PST to MSG Converter is the top software as this looks to be the direct tool for me when I achieved the conversion of thousands of PST files to MSG format. Give a venture to this software. I hope you will get successful results. You can try this tool for converting PST to MSG format.
