How to import emails from Lotus Notes to Outlook?
edited June 2019 in Q&A and Discussions
Take the help of the finest NSF File to PST Converter Online. This tool is useful to transfer unlimited Lotus Notes NSF files to Outlook PST format without losing information. The tool allows users to convert NSF files in batch to save time and effort. It successfully supports NSF files created by any NSF supportive tool. This software is compatible with all the versions of Windows OS & MS Outlook.
More Info;- NSF File to PST Converter
  • I found the response from Google to this fault, if you are looking help to data move query from Lotus Notes NSF to Outlook PST then visit here: https://www.sametools.com/convert/nsf/
  • With a NSF to PST converter software, it is very easy to move Lotus Notes emails and other data to Outlook without facing any issues. To know about such a software, visit: https://www.nucleustechnologies.com/lotus-notes-to-outlook.html
  • SiriSiri
    edited June 2019
    If you want to export Lotus Notes emails to Outlook very easily users can try the tool, Bitdataconversion Lotus Notes to Outlook converter. It converts multiple Lotus Notes NSF data to PST. It also exports NSF data to EML, MSG, and HTML formats. It provides the free demo version of the tool which helps to check all the functions and convert the first 25 items per folder
    More details, visit:- Convert Lotus Notes to Outlook
  • Bitacube Lotus Notes to Outlook Converter tool helps to migrate Lotus Notes to new PST, Live Exchange, Office 365, EML, MSG, HTML, vcf, csv etc.
    It has free trial which allows to save first 25 items per folder without software license purchase. Further, you can evaluate software features and take decision to purchase software license.
    It cost only $99 USD for home license.
    More information http://www.bitacube.com/nsf-to-pst-converter.html
  • To Convert Lotus Notes data in MS Outlook, use ToolsGround Lotus Notes to Outlook Converter Software to convert bulk and selective data from Lotus Notes to Outlook platform. This tool gives an easy and authentic process for moving the entire user's mailbox of Lotus Notes to Outlook, including email, attachments, contacts, calendars, journals, notes and to-dos and others.
    More info;- https://www.toolsground.com/nsf-to-pst-converter/
  • With the help of the most prominent third-party solution MailsDaddy NSF to PST Converter tool, you can convert Lotus Notes to Outlook and export multiple data files of IBM Notes in Outlook importable PST file format without any hassle. With this NSF Converter tool, one can import emails, calendars, contacts, tasks, notes, etc. in PST, EML, EMLX, MSG, MBOX, HTML, MHTML, and RTF formats and additionally migrate to Office 365 or Live Exchange Server platform. Get more: NSF to PST Converter
  • edited December 2019
    SysBud NSF to PST Converter is one of the best tools which easily convert Lotus Notes NSF file into PST, MSG, EML, MBOX, HTML, Office 365, Live exchange Server, etc formats. This software provides the best facility to split the large NSF file into small PST files. With the help of NSF to PST converter, users can migrate multiple NSF files into PST file format with all data items.
    To more information about the software, visit here:- Lous Notes to Outlook Migration Tool
