MBOX file to PST file Conversion tool
Try the best utility Regain MBOX to PST Converter for perfect Conversion results which easily Exports MBOX files to Outlook PST format in few moments. It has a simple GUI interface which easily performs MBOX to PST conversion. This Software allows user to save Converted MBOX file to multiple format like: MBOX file to PST, EML, MSG, EMLX, HTML and Office 365 Platform. User can save 30 emails per folder at free of cost.
Get this Software free trial version from here: http://www.mboxtopstconverter.emltopstutility.com/
    If you are looking for trusted MBOX to PST converter tool then, you must try MBOX to PST converter from Shoviv which can easily convert multiple MBOX files in PST format without any risk of data loss. Additionally, the tool loaded with enhanced features which makes possible the migration process of MBOX to Office 365 in an accurate manner. The tool support 20 email client which support MBOX file format such as Entourage, Thunderbird, Eudora, Seamonkey, Spicebird, Mulberry, etc. Using the trial version, you can also convert 25 items/folder as well.
    Download Now:- https://gallery.technet.microsoft.com/Best-MBOX-to-PST-converter-6762c7e5
    To convert MBOX to PST file, you can use Kernel for MBOX to PST converter software. It can easily convert MBOX/MBX/MBS/MSF emails to Outlook PST without making any change in original data. Try it: https://www.nucleustechnologies.com/blog/free-methods-to-convert-mbox-to-pst-file/
    Use safe migration tool i.e MailsDaddy MBOX to PST converter. It supports more than 25 email client mailboxes such as Apple Mail, Entourage, SeaMonkey, Opera, The Bat, Claws Mail, Netscape etc. The tool has many advanced solution to export MBOX data to Outlook without any hassle.
    Download it here: http://www.mailsdaddy.com/mbox-to-pst-converter/
    Shoviv EDB Recovery Tool is best software to https://www.shoviv.com/exchange-recovery.html[recover Exchange database files. It tests immoral Exchange Database (EDB) file and recovers all mailbox items including emails, attachments, contacts, calendars, notes, tasks, journals, and public folders. The Exchange Database Recovery tool can export the mailboxes directly to Live Exchange Server and Office 365.
    Read more - https://www.shoviv.com/exchange-recovery.html
    MBOX to PST Converter helps you to convert your MBOX files into PST format in a simple manner without loss of data and restriction.Thi­s is a reliable application to try. you can download a free version to understand its functions and working.
    For more details: http://www.outlookconverter.net/mbox-to-pst/
    edited October 2019
    With the help of WholeClear MBOX to PST Converter tool. This Software provides all servies to convert MBOX into PST files. I have also uses the WholeClear MBOX to PST Software thatswhy I suggest you by this tool.
    Visit here: https://www.wholeclear.com/mbox/pst/
    If you are looking for a fast and secure solution to convert many MBOX files to PST format then you should use any efficient third party tool. There are lots of third-party tools available on the web, but choosing the right tool is always a specific task for users. Here I suggest the best MBOX to PST converter tools such as Bitacube MBOX to PST Converter. It provides multiple MBOX file conversions into Outlook or multiple formats without any technical expertise. I highly recommend this tool as it supports 20 email clients for MBOX file formats such as Apple Mail, Gmail, Thunderbird, Eudora, Seamanaki, Opera Mail and more.
    You can check here this tool free trial version: https://www.bitacube.com/mbox-to-pst-converter.html
    If you want to transfer the MBOX file to Outlook PST file format. Try MBOX to PST Converter for Mac Software this utility migrate MBOX file to Outlook PST file format on Mac. Use MBOX to PST Converter for Mac tool gives you the best result after convert MBOX to PST file. It provides you with a stop solution for the successful conversion of MBOX files of Apple Mail, Entourage, Thunderbird or Power mail in Outlook PST file. This software supports all Mac OS versions like 10.6, 10.10, 10.11 and many more.
