Convert Lotus Notes NSF data to Exchange, and Outlook PST- Shoviv Software
By taking the help of Shoviv Lotus Notes to Exchange Migration, users easily convert their NSF data into Exchange and several interesting file formats such as Outlook PST, EML, MSG, HTML, vCal, vCard. It is very simple to use even a non-technical user can easily operate it without any technical skill and knowledge. The tool works with all versions of Lotus Notes, Outlook, and as well as Windows OS. Download its free trial version to check all the functionality and migrate the first 25 items per folder.
More Details, visit:- Lotus Notes to Exchange
    For easy and instant migrate your Lotus Notes to Outlook data with the help of NSF to PST Exporter tool. It converts all NSF mailbox data like contacts, email messages, tasks, appointments, attachments, notes, images, etc. from the PST file format. This tool easily supports all versions of MS Outlook office-365, live Exchange server, 2016, 2013 & all lower version.
    More Info:- NSF to PST Exporter
    By using an NSF to PST Exporter Utility, you can rapidly change Lotus Notes to Outlook file without facing any problems. NSF to PST App is such accomplished software, which can also help you to fix Notes errors all stored data within a few clicks.
    Though, this migrator tool comes with limits like it does not consent you to shift all data. Besides, the process is time-consuming mainly in case of huge and various Notes files. In the case of distant NSF, this practice won’t be capable to move your important data. Visit here: https://www.sametools.com/convert/nsf/
    If you want to perform conversion of IBM Lotus Note email files into an Outlook PST format easily, then I would like to suggest to you use This NSF to PST Converter software, The software transfers email items like contacts, calendars, tasks, journals, notes, email properties and more. With the tool, you can open converted NSF files in RTF, PDF, PST, MSG, EML, and HTML format. It can split converted PST file in MB size. The tool is fully compatible with all versions of windows and has various features which could learn from its free demo.
    Read for more information Visit on this website:-http://www.nsf-converter.com/
    edited December 2019
    If you are wondering for a third-party solution to convert Lotus Notes data in Outlook, Office 365, Exchange Server, etc. then I would like to recommend you, use MailsDaddy NSF to PST Converter tool. It is very helpful to solve all the issues of Lotus Notes to Outlook Migration without any data loss and alteration. With this handy tool, one can export all NSF emails, contacts, calendars, tasks, notes, journals, etc. in PST format with the same folder hierarchy, text formatting, HTML formatting, etc.
    If you want the convert Lotus Notes to Outlook then I suggest you use NSF to PST Converter Tool. It easily exports Lotus Notes Emails, Contacts, Attachments, and Calendar items, etc. The software provides a free Demo version for the user. The Demo version of the software export the first 20 NSF file from each mailbox.
    More Info- http://www.nsfto.com/pst/
    Download SysBud NSF to PST Converter, which helps you to convert Lotus Note to Outlook PST file format in just a few clicks. It has an interactive and user-friendly interface that enables the user to perform the migration process quickly. As well as provide the option to migrates NSF file into PST, MBOX, EML, MSG, Office 365, Live Exchange Server & some other formats.
    The utility is fully compatible with all the versions of IBM Lotus Notes and MS Outlook.
    Explore More: http://www.sysbud.com/nsf-to-pst.html
