OST4- OST Recovery
alexaleealexalee
edited May 2019 in General
Through the help of OST4 OST Recovery application users can easily convert the overall data from OST file to Outlook PST data file without any difficulty. It is a very safe and secure way for the conversion task. The features of this program are amazing in the conversion work. It supports all the version of OS Windows like 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit).
The users can export their resultant file into PST, EML, EMLX, MSG, vCal, vCard, and MBOX file formats. Apart from its support cloud-based application Office365 & Live Exchange Server that is an additional feature of its. Before the actual conversion work, it will display the preview of recovered mailbox then store the data into Outlook PST file format.
The installation of MS Outlook in the system is not necessary for the conversion work so you can convert OST data into PST data file in the absence of MS Outlook installation. It supports MS Outlook versions like 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019. The size of OST and PST does not matter for the conversion work.
The users can also take its free demo version to convert the first 30 emails from each and every folder free of cost but to convert more than 30 emails from each and every folder free of cost. If you are not happy with its work so you can return it under 30 days without any difficulty.
Read more: ost4.com
    With an OST to PST converter software, one can easily and quickly solve OST corruption issues and convert them int accessible PST formats. The software also helps to recover lost mailbox items from OST file. Try it: https://www.nucleustechnologies.com/blog/3-ways-to-view-corrupted-ost-file/
    Try OST to PST Conversion Software and recover corrupted OST data and convert into Outlook PST format with all Emails, Contacts, calendar , Notes, entries, and journals.This software supports Windows 10, 8, 7, Vista, XP and MS Office 2016,2013, 2010, 2007, 2003, 2002 (XP).
    _Read more information about this software and free download click here http://osttopstconversion-software.blogspot.com
    _
    Free Windows OST to PST Converter Tool, try its free trial version which will migrate your first 10 emails and if you want to switch the number of emails you essential to go for the OST to PST program licensed version. For more info guidance or about the software you can click here: https://www.sametools.com/convert/ost/
    Using this OST to PST Converter users easily export OST files with internal folders like inbox, contacts, task, attachments, appointments, calendars and outbox items to outlook PST formats without producing any difficulties.
    For more details: http://www.osttopst.mergepstpro.com/
    Just free download SysOZ OST to PST Converter demo version software which has simply repair corrupt OST file data and also convert 30 emails into PST Outlook file formats as well as you can see the converted emails items before the conversion process. This Convert OST tool is an excellent way to transfer OST mailbox items junk mail, contacts, calendar, notes, send items and deleted items, etc.
    Free Download: http://bit.ly/CNET-OSTtoPST
