Convert maildir to pst
With the help of SDR Maildir converter software you can quickly convert Maildir to PST outlook with it emails properties like as:- to, bcc, cc, subject, date and draft etc as well as this software also support all version of PST file as:- 97, 98, 2000, 2003, 2007, 2010, 2013, 2016 and 2019
READ MORE:- https://www.stelladatarecovery.com/maildir-converter.html
https://maildirconvertersoftware.wordpress.com/2019/01/03/stella-maildir-converter-software/
https://maildirconvertersoftware.wordpress.com/2019/01/22/best-maildir-converter-software/
If looking for a good solution then you must read this article which is mentioned below. In this blog, there are some manual hacks that will help you in importing Maildir files to PST format. And if these hacks are not helpful then you may also go with a reliable third-party solution which is also mentioned in the blog.
https://filerecoverytips.com/convert-maildir-to-pst/
Hey
Always try a tool that have a demo version so that you can utilize the productivity of the product. I am aware of a tool that will provide the Date Range Filter option. With that, you can split PST file as per your preferred file size. Eliminate Double items on the basis of To, From, Subject or Date. Works on the mail of Linux platforms like Dovecot, Mutt, MPOP, etc. Continue reading.
