The emulator is unable to verify that the virtual machine is running at VS2015
I have Unity for Hololen and VS2015 running at Windows 10 virtual machine. I have problems with running emulator on VS2015. Any tips how to make work?
The emulator is unable to verify that the virtual machine is running:
something happened while starting a virtual machine. Hololens Emuator failed to start.
The virtual machine management service failed to start the virtual machine Hololens Emuator.
  • AlexDAlexD ✭✭✭
    Do you mean you are running unity and Visual studio in a Win 10 virtual machine? Since the emulator itself is essentially a VM running in HyperV, you cannot run the emulator on a VM.
    If that's not the case, make sure that the HyperV service is up and running on your machine.
  • You need to be running Windows 10 Professional as described in https://developer.microsoft.com/en-us/windows/holographic/install_the_tools
    I am facing the same problem ,getting error "The emulator is unable to verify that the virtual machine is running" can someone help ?
  • JasJas
    edited July 2019
    Having the same issue! Screenshot below for the error which I get on the emulator screen.
    Hyper-V has been enabled at the Windows level and the corresponding settings at the BIOS level as well...
    shall I expect to see something in Hyper-V manager.
    Any pointers on this will be highly appreciated, as it has become a show-stopper for us to proceed ahead with any kind of development on this.
