Microsoft OST to PST Converter
SysOZ Software provide the excellent features export offline OST file into various formats
OST to PST
OST to EML
OST to EMLX
OST to vCal
OST to vCard
OST to MSG
OST to MBOX
OST to Office 365
OST to Live Exchange
etc……
Free Download: http://bit.ly/CNET-OSTtoPST
  • OST to PST Conversion Software to convert OST to PST outlook formats. The OST to PST Conversion Software to Convert OST file exchange from all OST versions and safely export OST to PST. Just Download OST to PST Conversion Software and fix all kind of Exchange issues. The OST to PST Conversion Software -repair OST & recover OST file to PST with emails/Tasks/Notes/Calendars & then save OST to PST.
  • Three months ago, I was trying to move all my emails files from OST to PST format. I used many manual methods but was unable to get accurate results. Then one of my colleagues suggested the OST to PST Converter. This is an advance tool for converting files. The OST to PST converter can support all the new versions of windows. This software also supports the latest version of Windows XP, Vista, 2000, 2003, 2006, 2010, 2013, 2019, etc… You can try this tool.
    Try this:-
    https://www.freeviewer.net/forum/how-to-extract-emails-from-outlook-ost-file
  • ATS OST to PST Conversion tool is the great opportunity for the Outlook users who are suffering from OST corruption problem. This is compatible with all the version of MS Outlook up to 2019. Users can easily maintain the integrity of OST file data systematically. You can see the preview of recovered mailbox before converting them into Outlook PST file with the entire data such as email, contact, inbox, sent item, delete item, draft, calendar, notes, contact, task, attachment, outbox (to, cc, bcc, subject, date and time). With the help of this software, users can directly import their OST data into a cloud-based application Office 365 and live Exchange server which is an additional feature of this tool.
    Read More: https://ats-ost-to-pst-converter-toolkit.en.softonic.com/
  • Support to get better deleted Outlook gadgets, which includes mail messages, folders, posts, calendar, appointments, assembly requests, contacts, distribution lists, responsibilities, assignment requests, journals and notes. Quickly and without problems recover messages or deleted email attachments out of your Microsoft mail field. No technical talent is needed for this healing software program software e mail. The Outlook OST records recovery software program program provides users with choice to lessen an outsized PST record at the same time as encountering corruption. The oversize OST files results in multiple troubles like OST facts loss and it gets hard to return over those problems and the most complex task is to get higher PST files in case any problem encountered.
    Know More - https://www.linkedin.com/pulse/ost-pst-converter-software-recover-corrupted-file-up-outlook-kumar/
  • Easily recover OST file into PST file format by using eSoftTools OST to PST Converter tool, this tool easily converts OST file into multiple formats like Office 365, MBOX, CSV, EML, MSG, vCard, HTML, PST Outlook. It does not need the installation of MS Outlook for the conversion of OST file and it smoothly functions with all version of MS Outlook 2000, 2003, 2007, 2010, 2013, 2016, 2019. A smart preview is shown to the user before the conversion of OST file, to make the conversion format confirm to the user. Users can easily convert up to 50 emails from each folder into each format by using the demo version available of this tool.
    Get more info:- http://www.ostrecoverypst.com/
  • You can try the most effective and easy to use **OST to PST Converter tool **to Convert OST to Outlook PST. This tool helps to access your inaccessible OST files in just a few minutes. This tool has the capability to convert OST Files into multiple formats such as- PST, EML, MSG, and MBOX. This software Imports OST entire data to a Live Exchange Server and Office 365. This Converter software also provides the facility to convert single or multiple emails from the OST file. Visit for more info:- http://www.osttopst-converter.com/
  • The only thing I can offer is my highest recommendation for the OST to PST converter by CoolUtils. The company came as a blessing to me that they helped me solved my burden in converting files. I am lucky to talk to one of their agents and he helped me do the steps from installation to running the software on my device. Five stars for you guys. Great job!
    You can call at +1 (855) 418-2323 ** or search **ost to pst converter coolutils. And after downloading it you can use it.
  • I would like to you advise another one latest application i.e. OST to PST Conversion. This utility helps you to effortlessly convert Outlook OST files to PST file format with all email properties, formatting, and attachments. It well-matched with all the advance and below versions of MS Outlook such as 2019, 2016, 2013, 2010 and etc. and Windows OS editions also.
    Read More Info,Visit Here:- http://www.sametools.com/convert/ost/
