MBOX to PST Converter Tool ?
I want to transfer my MBOX to PST file format. please let me know which is best method to perform MBOX to PST conversion.
    Now follow simple step and convert MBOX file to PST file by using this This MBOX to PST Converter tool, this tool Instantly Convert MBOX file to PST File in just few Clicks. Through this tool You can also convert AppleMail mailbox into PST file.
    Visit at ; https://www.downloadfreeware.org/mbox-outlook-converter/
    There is no such MBOX to PST Converter tool that is free of cost. Yes, free versions are available but have some limited features over purchased Software. Here I want you to refer MBOX Converter to export your MBOX file into Outlook. The free version of the tool can export some of your emails to PST. You can also purchase the software from the official site. Visit here to download the free version:- http://www.toolsbaer.com/mbox-to-pst-conversion/
    By using a MBOX to PST converter software, it is very easy to move Apple mail MBOX file to Outlook PST formats without any issues. Kernel for MBOX to PST Converter is such a software. It can help you to export MBOX/MBX/MBS to Outlook PST and Office 365. For more information, visit: https://www.nucleustechnologies.com/blog/import-mbox-files-in-to-thunderbird/
    edited March 2019
    If you are looking best Mbox to Outlook PST converter tool so I refer you try KDETools Mbox to PST converter software work very fast and gives 100 results in the conversion of Mbox file into PST file format. It always gives the expected result in all situation without any breakdown of data. It can convert multiple file format such as Mbox to PST, EML, HTML, MSG, EMLX, etc. It can convert easily encrypted and password protective files, it exports to all emails items like (inbox, outbox, sent items, folder etc.) This software supports all Microsoft outlook versions such as 2019,2016,2013,2010,2007 etc
    Here I would like to add one more software into this queue i.e. SysInfo MBOX to PST Converter, With this utility user can convert MBOX files into multiple formats like PST, MSG, EML and RTF formats. Here you can download the software and convert multiple MBOX files into PST format at a time. https://download.cnet.com/SysInfoTools-MBOX-to-PST-Converter/3000-2369_4-77504640.html
    I will suggest you to use Total Mail Converter developed by CoolUtils. This will help you to manage your emails outside your email client. You can even convert your MSG/EML files to PDF, DOC, XLS, PST, EML etc. If you still have a question you can directly call them on - +1 (855) 418-2323
    More details - https://www.coolutils.com/TotalMailConverter
    I suggest you, use this converter which converts MBOX to PST data very quickly without any alteration during conversion . Mbox converter helps you to convert the data into various formats such as EML, EMLX,HTML ,PDF. Mbox converter supported by Thunderbird,Entourage,Apple Mail, Eudora and 20+ Email Clients .
    Click here to Know More : http://www.mboxmails.com/
    edited August 2019
    Looking a best MBOX to PST Converter, then adopt MailsDaddy MBOX to PST Converter that easily migrates large mailbox to Outlook PST format. User can use this solution all type of mailbox and perform the conversion from MBOX to PST, HTML, RTF, MHTML, MSG etc. The best part of the solution is that it allows to export filtered email using search criteria To, From, Subject, Date etc.
    MailsSoftware MBOX to PST Converter is a quick and simple solution to convert all MBOX to Outlook to PST. It supports more than 25 MBOX based email clients MBOX files to convert to PST format. It easily adds and browses single and multiple MBOX files at a time. The software quickly scans the MBOX items and generates a complete preview of data. It exports MBOX data to PST, MSG, RTF, EML, EMLX, HTML, and MHTML formats.
    Get More Info- Convert MBOX to PST
    SysBud MBOX to PST Converter well-developed Software which easily converts MBOX file into PST file format.
    It offers the following features:
    1:- Migrates multiple MBOX files to Outlook PST format at the same time.
    2:- Exports huge MBOX/MBX/MBS files into PST format and save them into a new file
    3:- Supports all MBOX based email client like- Entourage, Spicebird, Netscape, ClawsMail, Pocomail, AppleMail, OperaMail, Eudora, Evolution, Mulberry, SeaMonkey, etc.
    4:- Transfers multiple MBOX files into single and separate PST file.
    5:- Supports all version of Outlook and Windows OS.
    6:- Preserves internal folder structure, mail properties, and attachments.
    There are many tools available in the online market place that allow you to easily convert email database files from MBOX format to PST for Outlook. Well, I too had to face this problem, then I decided Bitacube MBOX to PST Converter. It provided me excellent features to convert MBOX file to PST format in a few clicks.
    Read More: https://www.bitacube.com/mbox-to-pst-converter.html
    rosefreshrosefresh
    edited September 2019
    To convert MBOX mailbox to PST format you may use ZOOK MBOX to PST Converter software that is helpful for both professional and non-professional users. Fully supportable to all 30+ MBOX based email applications. Allows to import MBOX files in Outlook 2016/2013/2010/2007/2003/etc. Provides fully 100% safe and secure conversion without any alteration of data.
    Read More Info,Visit Here:- https://filehippo.com/download_zook-mbox-to-pst-converter/70205/
