How to recover corrupted OST file into PST?
If you are confused regarding the recovery of OST file, simply download and use eSoftTools OST Recovery Software. This tool easily and instantly recovers all damaged OST file and folders E-mails, Chats, Contacts, Appointments, Inbox-Outbox items, Drafts, Sent Items, Calendar, Tasks, Notes, Journal folders. Also, it safely converts OST file into Office 365, MBOX, CSV, EML, MSG, vCard, HTML, PST Outlook. User can easily check the conversion format by the smart preview available before the conversion. For converting OST file into other formats this tool does not require installation of MS Outlook and it supports all version of MS Outlook such: 2000, 2003, 2007, 2010, 2013, 2016, 2019. A FREE DEMO version is also available of this tool easily up to 50 emails can be converted into all formats.
Get more info:- http://www.ostrecoverypst.com/
Also visit here:- https://gallery.technet.microsoft.com/Best-way-to-recover-and-3312ac3a
  • If you need to know how to recover corrupted OST file into PST, then I would recommend you to check out a free trial version of OST to PST Converter tool and know step by step recovery and conversion process. It also lets the users convert first twenty-five items per folder.
    Get more info: https://shovivtools.wordpress.com/convert-ost-to-pst/
  • OST to PST Migration App is a perfect solution for recovering and extracting exchange OST mailboxes into Outlook PST files. This OST to PST Migration App to recover OST to PST has widely scanned the OST file and recovers the entire mailbox listed in a selected OST file. It can recover emails, contacts, journals, and permanently deleted emails, notes, sent emails, drafted emails, appointments, alarms, and schedules to Outlook PST files.
    View more information at- OST to PST Migration App
  • InQuit OST to PST Converter is best solution for the problems that you face while converting the data. So InQuit OST convert will resolve all your problems and make your work easy and fast for you. This tool have all the features that provide the best results for data conversion. With the help of this tool you can recover the Emails with respective ‘subject’, ‘to’, ‘cc’, ‘bcc’, ‘date’ and ‘time’. This tool also support all the latest version of the MS Outlook version 97, 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 up to 2019. This tool support file formats like EML, MSG, vCard, vCal, EMLX, MBOX, and HTML.
    Read More Info: https://inquit-ost-to-pst-converter-toolbox.en.softonic.com
  • I am delighted to provide a reference for the company CoolUtils and their product, the OST to PST Converter. Using the tool has been a great help to me as it not only converts corrupted and damaged files but gives me quality and reliable output. I was amazed that I don't have to waste time using other tools. Plus the output is really great. The software is very user-friendly and very safe with my device. A must for you guys out there.
    You can search - "ost to pst converter coolutils" and download it.
  • Hi If you want to recover the corrupted Outlook OST file then I suggest you to use OST email Recovery Application. This software provides the option to recover damaged as well as the Orphaned OST file. The user can save the resultant OST file in PST file format. This application is compatible with Microsoft Outlook 2019 and its below version. To know more, the user can try the demo version of this software.
