OST to PST Converter Freeware software
There is only one software which can scans, recovery and migrate the data in just few minutes and the name of this best software InQuit OST to PST Converter. This software is made with highly advanced technology but still this software is very use as the GUI(Graphical User Interface) of this software is explanatory this is the reason why this software is very easy to use. This is the only software which compatible with version latest version of Exchange Server, windows and Outlook. This software can supports Support all MS Outlook versions and easily work with all Windows OS 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit) safely & securely. It supports live Exchange Server 5.0, 5.5, 2000, 2003, 2007, 2010, 2013, 2016 an also support the Microsoft window 98, 2000, 2002, 2003, 2007, 2010, 2013, and 2016. With the help this software you can convert your data into formats like PST, EML, MSG, vCard, vCal, EMLX, MBOX, and HTML. You can also avail the free demo version of this software and you will be able to convert 30 emails. You can easily convert the mailbox email, draft, task, attachment, sent-item, delete item, draft, calendar, notes etc. This is the only software which can keeps originality of the data. Your data will same even after the conversion. With the help of this software you can avail the 30 days money back policy.
Read More Info: https://inquit-ost-to-pst-converter-toolbox.en.softonic.com
  • To know in detail about OST to PST Conversion, read this blog:
    https://shovivtools.wordpress.com/convert-ost-to-pst/
    This blog will allow you to download a free trial version to know in detail about its features and working process. It will allow you to convert first twenty-five items per folder as well.
    Hope it will help you to accomplish your job.
  • Go with OST to PST Conversion Tool which is a safe solution to fix and recover your corrupted OST files and convert OST to PST, EML/EMLX/MBOX/MSG, and other different formats. It also helps to save OST data in the desired location.
  • Try ToolsGround OST to PST Converter software, this OST file conversion software perfectly recovers and convert OST file to several Outlook file formats like PST, EML, MSG, ICS, vCard, HTML, MHTML and MBOX. This OST to PST program comes with relevant features of PST split option, which assist you to retrieve Offline OST in PST format. This software supports all MS Outlook version includes Outlook 2016 versions
    More Info:- toolsground. com/ost-to-pst-converter/
  • Use the advanced version of eSoftTools OST to PST Recovery Tool to recover and convert OST file. This tool instantly converts OST file into PST Outlook just on minimum numbers of clicks and it offers various formats for the conversion of OST file like Office 365, MBOX, CSV, EML, MSG, vCard, HTML. This program does not require installation of MS Outlook for converting OST file into PST Outlook Outlook. A smart preview feature is available just before the conversion of file, by this preview user can view and confirm the conversion format.
    Get more info:- https://www.esofttools.com/ost-recovery/
  • ethanickethanick
    edited September 2019
    You can try the new and best WholeClear Migrator Converter Tool which can also convert your all OST file to Outlook PST file format including emails, attachments , calendar, contact etc. Its size independent application and you can also try free demo version.
    Visit Now: https://www.wholeclear.com/migrator.html
