Excellent OST to PST Converter Safe Tool
One of the excellent third party tool that is SysOZ OST to PST Converter Software which is made up with the highly advanced algorithm for recovering the data from damaged OST file and convert into Outlook PST file, MSG, EML, MBOX, vCard, EMLX, and vCal formats. During the conversion process, the data integrity of your data will same as before. For the conversion, you need to follow simple steps and the conversion will complete. You will get to know the features of the tool very clearly in the free demo version of this tool.
  • Use OST to PST Converter Software is a most reliable & easy way to transfer lost data from orphaned OST file and convert email from outlook OST file into PST with all relevant folders:- Inbox, Draft, Journals, Tasks, Calendars, Outbox, Sent Items, Deleted Items, Notes, and Contacts.
    More Info;- http://www.osttopst.adwages.com/
  • I would like to suggest here a very information article about free methods of OST to PST conversion, read it: https://www.nucleustechnologies.com/blog/free-methods-convert-ost-to-pst-file/
  • edited August 2019
    You can take help of ToolsGround OST to PST Converter to export your .ost files to .pst format. It is always suggested by users to convert and recover your OST mailbox data and access it in your Outlook without any problem.
  • Best OST to PST Converter tool is available by eSoftTools, this tool recovers all corrupted OST file and folders including E-mails, Chats, Contacts, Appointments, Inbox-Outbox items, Drafts, Sent Items, Calendar, Tasks, Notes, Journal folders. A smart preview is shown to the user before the conversion of OST file, it does not require installation of MS Outlook for the conversion of OST file. A FREE DEMO version is also available of this tool, easily up to 50 emails can be converted into all formats.
    Get more info:- http://www.ostrecoverypst.com
  • Through the help of standard ATS OST to PST to Converter tool, you can access lost and permanently deleted data and restore them into PST which is stand for Personal Storage File. Using this utility you can export email, inbox, outboxes, sent-items, deleted-items, drafts, contacts, calendars, notes (To, Cc, Bcc, Subject, Date and Time) in a couple of clicks. This application support all the version of MS Outlook 97, 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019.This provides lots of file formats like PST, EML, MSG, HTML, EMLX, vCal, MBOX and vCard, Office365 & Live Exchange Server for restoring data after the conversion. It gives 30 days money back guarantee.
    Read More Info: Exchange OST to PST Converter
  • If you are looking for manual methods to convert OST files to PST files than you should read this blog-https://www.datainfotools.com/blog/manual-methods-to-convert-ost-files-to-pst/
  • I would like to note here OST to PST Conversion software that quickly migrates OST to Outlook PST. This program supports all versions and effectively stores MS Outlook data in an offline folder to view data without linking to the internet. The file size is not an issue to get satisfactory conversion results.you can download the free trial version which converts few items from each folder.
    you can download this tool from here:- https://www.toolsbaer.com/ost-to-pst-conversion/
