MBOX to PST Converter Software
There are so many tools available for the Conversion of MBOX file to PST file but you can refer to some Reliable tool for the purpose. I Recommend Regain MBOX to PST Converter Software from which I used personally. This Software Allows user to Convert MBOX file to PST, EML, MSG, EMLX, HTML and Office 365 Platform. This Software Compatible with all MS Outlook version 2003, 2007, 2010, 2013, 2016 and 2019.
Download this Software free demo version from here: http://www.mboxtopstconverter.emltopstutility.com/
    If you are looking for a resolution which can help you to import MBOX files into Outlook PST then I would propose you attempt a free demo version of MBOX to PST Convert Tool. This converter software for easy and error-free conversion of OST files to PST and many other file formats, including MBOX, EMLX, EML, and MSG. For More information visit here: https://www.sametools.com/convert/mbox/
    MBOX to PST Converter is the easiest tool to migrate all mailbox data cratered by email clients including Apple Mail, Thunderbird, Entourage, Postbox, Eudora, PocoMail, Netscape, Opera, Spicebird, PowerMail, Claws Mail, Evolution, SeaMonkey, Sylpheed, Mulberry, Sparrow, GyazMail, Gnu, and The Bat! This software gives the option to preserve converted file where it can store. http://www.toolsbaer.com/mbox-to-pst-conversion/
    KDETools MBOX to PST Converter is really an amazing tool which can efficiently convert the MBOX file to PST Format. It has the capability to recover corrupt MBOX files, convert MBOX file to Outlook PST and save it to many formats like PST, EML, MSG, HTML & MSG and fast conversion of data. It will convert your entire mailbox with zero error. It also supports all versions of MS Outlook and Windows.
    ToolsGround MBOX to PST Converter is a standalone tool. It doesn't require installation of MS Outlook. 100% data integrity will be maintained all over the processing. The software is an advanced tool which supports all versions of MS Outlook.
    More Info:- https://www.toolsground.com/mbox-to-pst-converter/
    When we are talking about the conversion of MBOX to PST format to access Thunderbird data in Outlook, then you must need to use MBOX to PST Converter for Mac. After the successful MBOX to PST Conversion, users can securely Convert MBOX file to Outlook without missing any data on Mac OS. It consists of many advanced features by which users can safely migrate MBOX file into Outlook PST format in just one click. This software supports all Mac OS versions.
    For more information visit here:- https://www.mailvita.com/mbox-to-pst-converter-for-mac/
    edited December 2019
    Best software is MailsDaddy MBOX to PST Converter, user can use this flawless solution and migrate single or separate MBOX file into Outlook. This multi-window application allows user to export MBOX file into Outlook PST format. User can also use the tool to export MBOX data into Office 365, Outlook.com, Live Exchange, HTML, MTHML, RTF and many more.
    visit: https://filehippo.com/download_mailsdaddy-mbox-to-pst-converter/
    I would suggest a fast and secure way to convert MBOX file to PST file formats without any loss of data such as Bitacube MBOX to PST Converter. If you are a technical knowledge-based personality and you have fewer MBOX files, then you can use the manual method because the manual method is a complex and time-consuming process. It provides a powerful algorithm that allows to the users add & export multiple MBOX with their attachments, attributes & properties with no data loss. Thus, it helps to convert MBOX to PST quickly and safely without losing or tampering any data. You can check here this tool free trial version:https://bitacube.com/mbox-to-pst-converter.html
