Convert OST to PST
SharyShary
If you want to convert OST to PST the Emails, inbox, outbox, sent-items, deleted-items, drafts, contacts, calendars, notes (to, cc, bcc, subject, date and time) you can use the InQuit OST to PST Converter. You can have the free demo version of this software with the free demo version you can convert 30 emails without paying penny. You can try the free demo version of this software before you purchase the original one. You can download the free demo version of the software from the official website of the InQuit Software. I would like to tell you some of the main features of this software.
  • OST conversion supporting this format PST, EML, MSG, MBOX and HTML.
  • Office 365 & live Exchange Server is the additional features of this tool.
  • This is also supported live Exchange Server 5.0, 5.5, 2000, 2003, 2007, 2010, 2013, 2016.
  • These applications provide 24x7 technical support facilities.
  • This application can recover all permanently delete files easily and securely.
  • You can easily convert multiple large OST files to PST without any changes or losses data.
  • Tested on the very large size of Outlook OST file database in the laboratory.
  • This tool support all the version of MS Outlook 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit)
  • You can export your corrupt data into new PST data which include Emails, inbox, outbox, sent-items, deleted-items, drafts, contacts, calendars, notes (to, cc, bcc, subject, date and time) with 100% guarantee.
Read More Info: https://inquit-ost-to-pst-converter-toolbox.en.softonic.com
  • Get a reliable and fast conversion process to convert unlimited OST files into PST, EML, and MSG format using OST to PST Converter tool. With this help of this tool, OST users can also repair corrupted OST files, restore deleted items and export OST to Office 365 and Live Exchange server.
    Get More Info: http://www.ostmailrecovery.com/
    One can also download a free trial version of OST to PST Converter to check out its workability and features.
  • The OST to PST Converter software easily convert OST File to PST Outlook file with emails, contacts, calendars, task, notes inbox items, outbox items, journals, and appointments. OST Converter Software allows users to convert selective single and multiple folders from OST to PST, EML, MSG, MBOX, and EMLX Format. The software works on all OST File versions included- 97, 2000, 2002, 2003, 2007, 2010, 2013 and 2016.
    More Info;- http://www.osttopst.adwages.com/
  • jackbryanjackbryan
    Use the best mode for the conversion of OST to PST Outlook, eSoftTools OST Recovery tool is the perfect recovery and converter tool. This tool offers the conversion of OST file into multiple formats like Office 365, MBOX, CSV, EML, MSG, vCard, HTML, PST Outlook. It smoothly supports all version of MS Outlook 2000, 2003, 2007, 2010, 2013, 2016, 2019, it does not need installation of MS Outlook for converting OST file. A FREE DEMO version is also available of this tool easily up to 50 emails can be converted into all formats.
    Get more info:- http://www.ostrecoverypst.com/
  • Easily export OST file into multiple formats Office 365, EML, EMLX, HTML, PDF, MBOX, and PST Outlook to recover the data. Export using OST to PST converter tool. This tool smoothly supports all version of MS Outlook 2000, 2003, 2007, 2010, 2013, 2016, 2019 and it does not need installation of MS Outlook for the conversion of OST file. Before exporting files into another format a smart preview is shown to the user to confirm and check the conversion format. Visit for more info:- http://www.osttopst-converter.com/
  • If you have damage OST file data and you think how can I convert OST to PST file so, now stop thinking just download best ToolsGround OST to PST converter software which quickly get rid exchange OST file errors and convert them into working MS outlook inbox, outbox, sent mail, junk mails, deleted emails, journal, contact and calendar and support office 2019.
    More Info:- toolsground. com/ost-to-pst-converter/
  • There are various conversion tools for converting OST file to PST file format. But some of them are good for OST to PST conversion. After searching on the internet I have found IGNISSTA OST to PST Converter Tool. You can try this software to convert OST data to PST without any data lose. This Software is 100% reliable and safe for the OST to PST Converter. It provides you some important features.
    • Multiple OST File Conversion
    • Inaccessible & Corrupt OST File Conversion
    • Quick & Fast OST to PST Conversion
    • Split Large OST file into Small Size
    • Converts without Data Loss
    • Convert Emails with Filter
    IGNISSTA also provide demo version for testing this software. With demo version you can export 50 items from every folder.
    For More Information :- http://eraser.heidi.ie/forum/threads/ost-convert-to-pst-file.13910/
