Can not deploy app correctly in Hololens
In general, steps fo deploying one uwp app are as follows (deployed in Holoens):
1. Compile correctly in VS/Unity.
2. Build in Unity with setting (uwp platform, proper version of sdk and so on).
3. BTW, remeber to make a right setting in Edit - Project Setting - Player - XR and Publishing Settings.
4. After building in Unity, generating a .sln file in a new folder (such as App or sth like that). Actually after building, u could see two new folders: one is App (or you could rename this new folders) and another is UWP.
5. Aimed at Hololens1, we should choose x86 platform, master and remote device (rmb to write the right ip address), btw if hololens2, it should be arm.
Actually I go smoothly in all those above steps. And transferring the uwp app (around 420MB) into Hololens1. Guess what? there is nothing in the screen. Although, according to one website whick is linked to hololens1 (just input: https.ip address in the browser), the app really runs. Howeverk, I did not see anything in the screen of Hololens1. And the most confusing thing is, even, there is not occurring "Made with Unity". As we all know that generally, there is ocurring "Made with Unity" sign before you using this app. I tried almost what I could try, I still did not fix this problem. Meanwhile, there is limited reports and information in Stackoverflow, Google, Github and some other websites.
Actually, I asked the same question in this link: https://developercommunity.visualstudio.com/content/problem/623241/can-not-deploy-app-correctly-in-hololens.html; but there is no reply : (
I also have deploy problems. I successfully deployed it to local PC simulator (Mixed reality portal). But I can't deploy it to Hololens.
Have you solved this problem? I came across exactly the same problem, it cost me much time and I have tried all I can but failed.
Did either of you try reporting a problem via Feedback Hub using your HoloLens like the Microsoft employee mentioned in that link? If you give a lot of details (like above with the steps) they tend to take the most action using that method above.
