How Can I Combine Multiple PST Files into Single PST ?
Amaya_SAmaya_S
edited July 2019 in General
If you looking for some reliable and cost-effective solution to combine multiple PST Files into single, then I would recommend KDETools PST Merger Software. The software easily combines the PST data in one single PST file, deleting all duplicate and deleted items from the file itself. Additionally, if offers you with other important feature to manage PST file. It is easy to use and capable to works with all Outlook versions like Outlook 2019, 2016, 2013, 2010, etc as well as Windows.
Features of Outlook PST Combiner Tool
*Merge multiple Outlook data files into a single PST file without losing any data.
  • Combine Outlook emails, contacts, calendars, and other items.
  • Merge particular Outlook contacts and calendars of PST file.
  • No file size limitations to combine several PST files.
  • Removes duplicates emails from PST.
  • Compatible with all Windows Operating System.
  • Try this free PST Merge tool which can easily combine multiple PST files into one PST including calendars, emails, contacts, notes, and tasks.
    Advantages of this PST Merge tool:
    • Combine multiple PST into one without losing any data.
    • Join Archive and Password Protected PST files.
    • Removes duplicates files and junk folders from PST.
    • Merge particular folder like contacts, calendars.
    • Free preview of all PST files before merging into one.
    Read for more info:-http://www.merge-pst.com/
  • Free Download SysTools PST Merge Tool and easily combine multiple PST files into a single PST file. The software is easy-to-use and offers multiple features so that users can easily merge Outlook PST files.
    Steps to Combine Multiple PST Files Into One
    1. Download and Launch the Merge PST Tool
    2. Add PST file or folder
    3. Select Options- Join, Merge or Merge Contacts
    4. In the advanced option, choose Split PST, Remove Duplicates and Exclude Deleted Items option
    5. Click on the Merge PST files button.
  • You can try ToolsGround Merge Outlook PST software to easily merge multiple PST files into one. This tool allows you to combine all Outlook data files with emails, calendars, notes, contacts and much more. It comes with simple GUI so that non-technical users can easily perform the task. The tool supports all PST file of Outlook 2016, 2016, 2013, 2010, 2007 and other versions.
    More Info;- https://www.toolsground.com/merge-outlook-pst/
  • You can try the advance Merge PST file, for merging your big and small files into a single PST file. You can select your files before transfer and install them into existing PST file or you can create a new PST folder. '
    Visit here:- https://www.mailsclick.com/merge-pst-file/
  • I would like to suggest Ignissta Splitter and Merger software which provide best solution to merge multiple PST file to single pst file.
    1. No File Size Limitations, Merge unlimited PST files
    2. Support all MS Outlook Version 2019, 2016, 2013, 2010, 2007
    3. Remove Duplicate emails while merge multiple pst file
    4. Merge multiple pst file and create new pst file or you can merge with existing PST file as well
    Download Demo version and Merge PST file https://www.ignissta.com/pst-splitter-merger/
  • Try the online tool for merging Outlook data, Free Download link here:
    https://www.sametools.com/merge/pst/
  • Hello
    If anyone wants to merge the multiple PST file then I would suggest trying to use the ****KDETools PST Merger****
    Merge various PST files Calendars, Contacts, Emails and all
    It supports in ANSI and UNICODE.
    This tool Supports without installing MS-Outlook.
    There are no file size limitations.
    Supports all the Version.
    More Details: http://www.thunderbird2outlook.com/pst-merge/
  • Here is an advanced software to merge multiple PST files into single PST file. With advanced features and phenomenal GUI, this software stand apart from many other software to merge PST. Download its free demo version and check out your new PST file preview in order to proceed further. Download the link from here https://www.stellarinfo.com/email-tools/outlook-toolkit.php
