3D video (SBS, TB) on HoloLens
Will it be possible to view standard 3D video content (SBS, TB, etc.) through HoloLens?
If answer is "no" for built-in capabilities, will it be possible to control each eye's display to parse video frame and produce 3D effect?
1
This discussion has been closed.
you could create this in unity
Control per-eye display in unity? How? Have an example?
well usually unity VR has 2 camera's that represent each eye. So you would render whatever content you want to each one of those cameras
Yea, but how to make sure each camera will be rendered by different eye display on holo?
Well... It was easier than I thought and without Unity.
In basic UWP app, XAML MediaElement supports Stereo3DVideoPackingMode and Stereo3DVideoRenderMode which can automatically render 3D video (at least if DisplayProperties.StereoEnabled == true) and video file(encoding, packing mode) is supported by MediaElement.
Hi AlexG,
Have you created live streams from one or more cameras using MediaElement with Stereo3dVideoPackingMode? It looks like this may be possible with MF_SampleExtension_3DVideo, but after scouring the web I have found no examples. Lots of warnings that this wasn't working in Win8, but no information whether or not it is now supported in Win10.
Thanks, Jay
Nope.
Also not tried how Stereo3DVideoPackingMode/Stereo3DVideoRenderMode works on HoloLens... Still awaiting for the device
maybe this link will help
http://bernieroehl.com/360stereoinunity/
